Author Topic: Vr6 Maf question  (Read 2071 times)
Offline mar_k
Vr6 Maf question
« on: 19 August 2012, 21:14 »
When fitting a Vr6 Maf sensor do you require a different TIP or is the normal Forge TIP ok?
Engine code is AUM.
I have used the search function and nothing comes up.
Offline Chris.
Re: Vr6 Maf question
« Reply #1 on: 19 August 2012, 21:19 »
You dont need VR6 on a AUM...
Click For Build Thread
Offline mar_k
« Reply #2 on: 19 August 2012, 21:33 »
Not at all?
Thats good to know!
Offline Chris.
« Reply #3 on: 19 August 2012, 21:40 »
nope!
Offline Prawny
  • R-tech power!!!
« Reply #4 on: 20 August 2012, 11:12 »
depends what spec he's going for doesn't it Chris?
You would never fit a VR6 housing or sensor though, as it's the totally wrong type for an AUM. if you require a larger housing for an AUM, you use the S3 / LCR / TT housing, and you can retain your sensor in the larger housing.
If you're on the ko3S though it's not needed, although many tuners will want one for a hybrid.
Offline mar_k
« Reply #5 on: 20 August 2012, 16:51 »
Cheers Prawny, The car in question has been having problem with the maf,
If was failing every so often, The induction kit was replaced with a standard airbox and filter,
It ran great for a few months, Fitted a new piper cross panel filter, Dry filter so no oil and 3 days later the MAF has failed again.
Anyone know why?
Offline jamie1989
« Reply #6 on: 20 August 2012, 17:10 »
Are they genuine parts? Bosch units?
1.6-1.8t AGU K03s, Forge actuator, Forge 007p, turbo back exhuast, Ths front mount, Catch can, 5 piece silicone boost pipes and creation sports tip. Stage 2 atm 232bhp 270lbs. Waiting for custom mapping :-)
Offline mar_k
« Reply #7 on: 20 August 2012, 17:13 »
Yep! lasted fine with the standard filter but again problems as soon as we moved away from standard.
The MAF is still under garantee so its going back tomorro
Offline jamie1989
« Reply #8 on: 20 August 2012, 17:23 »
That is just bad luck sorry mate, Iv had mine on for a good while. Iv even sold one to Wazzer and never had any problems either.
Iv got one spare left but its in my VR6 maf housing now ready for my remap.
I always keep atleast one spare  :grin:
Offline mar_k
« Reply #9 on: 20 August 2012, 17:26 »
I can understand why,
Its a mates car so Im not that fussed, Hopefully he will get it exchanged by the weekend as the car is meant to
be going on Power Engineerings Rolling Road on saturday.
