Author Topic: RNS510 Firmware Update 3810 / 4020  (Read 6013 times)
Offline Rislar
« on: 19 August 2012, 12:23 »
PLEASE NOTE NEITHER I OR GOLFGTIFORUM WILL BE RESPONSIBLE IF YOU UNDERTAKE THE PROCESS DETAILED BELOW AND SOMETHING GOES WRONG. YOU DO SO AT YOUR OWN RISK
Firmware 3810. It took about 50 minutes and upgraded successfully.
I had a Revision C unit and was previously running 2660 firmware:
I now have a "Version Information" menu item when I hold down the "Setup" button. When I click this it shows the following:
Delivery part number: 1T0035680D
HW-Version: H06
SW-Version: 3810
Active map coverage: West Europe
Active map supplier: Navteq
Map version DVD: 7074
The firmware upgrade deleted the maps and music on the HDD so i just reinstalled the V6.1 maps and added some music.
Nice new VW logo on startup and updated graphics and animation.
I followed these instructions and got the firmware from here:
http://www.mk5golfgti.co.uk/forum/index.php/topic,23779.0.html
I used the windows 7 to write the disk ( Maxwell DVD + RW ) or rather the image and had no problems with the install, it took around 50 mins.
Firmware 4020.
As above, took around 1 hour this time though, at first no controles on the steering wheel worked and the bluetooth module was missing but a reset after install put everything back.
My System now looks like this:
HW-Version: H06
SW-Version: 4020
This is the sourse i used for the Firmware 4020
https://docs.google.com/file/d/0ByTpaBJxxQsBY1RJNVBXajB6OEE/edit?pli=1
Theses are the differences from FW3810
1: NEW Faster navigation and user interface
2: NEW Automatic illumination control
3: NEW Enhanced destination input
1: The map scrolls smoother and faster in 4020.
2: Until now I haven’t tried it in twilight/darkness etc.
3: It’s faster when you enter cities/addresses etc.
Some pics:
More to follow...............
« Last Edit: 19 August 2012, 19:31 by Rislar »
Offline smoggy
  • 2011 Golf GTI *DSG*
Re: RNS510 Firmware Update 3810 / 4020
« Reply #1 on: 19 August 2012, 13:31 »
Top stuff..thanks for the info  :grin:
2011 Gti * dsg * sat-nav * r-pack * etc
Offline Rislar
« Reply #2 on: 19 August 2012, 13:39 »
You never know someone might wanna try it  :smiley:
Offline smoggy
« Reply #3 on: 26 August 2012, 18:26 »
Rislar,
Thanks again for the info, i picked my car up on Friday and am really pleased with it  :grin:
My info / software is:
HW- version H55
SW- version 3970
MAP version 7551
Do i need to update it ?
« Last Edit: 26 August 2012, 18:29 by smoggy »
Offline Rislar
« Reply #4 on: 26 August 2012, 18:31 »
Hi smoggy, you've the latest or very near latest version so id leave it fella  :smiley:
Offline smoggy
« Reply #5 on: 26 August 2012, 18:48 »
Cheers pal - i asked the dealer to check, they said it was ok- but then they would  :huh:
Offline Rislar
« Reply #6 on: 26 August 2012, 18:57 »
The new map version is 7692 so your on the one before V8 so its not a problem. Your right about asking though as they will fob you off   :rolleyes:
Offline smoggy
« Reply #7 on: 26 August 2012, 19:11 »
To be fair its a thumbs up to Pulman VW Durham...been spot on so far
Offline smoggy
« Reply #8 on: 26 August 2012, 19:13 »
One more for the album  :grin:
Offline Rislar
« Reply #9 on: 26 August 2012, 19:14 »
Lovely looking car  :cool:
