Author Topic: how to get the windows to work with fob  (Read 2186 times)
Offline markgti1.8t
« on: 18 August 2012, 20:07 »
hi there
can some one tell me how to get the windows to work with the fob thanks
« Last Edit: 18 August 2012, 20:12 by markgti1.8t »
AGU fk coilovers Powerflex top mounts full 3inch decat turbo back viper induction kit fmic vr6 clutch g60 flywheel catch can 007 forge dv Power flex wishbone bushes  Power flex dog mount under brace JOM  ADJUSTABLE Drop Links Walbro 255lph INLINE Fuel Pump wmi now fitted WAITING TO FIT VR6 MAF SAAB RED TOP INJECTORS STILL TO BUY K300 TURBO  CON RODS LSD
Offline AD1.8T
Re: how to get the windows to work with fob
« Reply #1 on: 18 August 2012, 20:36 »
Vagcom  :cool: maybe tacho
Offline Scott D
« Reply #2 on: 18 August 2012, 21:26 »
VDS Pro and a very old laptop with serial port connections.
You can buy a device that plugs into the OBD port which reprograms the central convenience module adding fob control - KWP1000?
Surely will be someone on here locally with the software who could do it for beer monies  :smiley:
2003 1.8T GTI 180 - APR Stage I, S2000 Filter, R-Tech Supersize TIP, Bilstein B12 Suspension, 18" OZ Superleggera, Recaro Heated Leathers, US Spec Rear Lights, N249/SAI/PCV Delete
1.8T AUQ - 241bhp & 286 ft-lb
R-Tech Map, Forge FMIC, SFS Oversized TIP, Ported Manifold, Milltek Turboback non res exhaust, Forge 007p, N249 & N112 delete, SAI delete, S2000 Air Filter, Sachs clutch & Lightweight Flywheel
Offline markgti1.8t
« Reply #3 on: 18 August 2012, 21:28 »
that would be great if someone could do that  :smiley:
Offline dasan
« Reply #4 on: 19 August 2012, 00:23 »
If you buy a vag-com cable off ebay you can use this guide..
http://uk-mkivs.net/forums/t/472146.aspx
VW Golf GTI - 1.8T 2003 - Reflex Silver
Offline Scott D
« Reply #5 on: 19 August 2012, 09:39 »
Good find
Will give this a try later on
Offline bobbarley
  • I'm kind of a big deal...
« Reply #6 on: 19 August 2012, 10:17 »
I could be wrong, but I think it depends on the mk4 and key?
I can only make my windows go up/down by putting the key into the lock and turning. It doesn't work via the buttons. Mines an early '99 GTI.
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #7 on: 19 August 2012, 10:41 »
It's down to the CCM by the look of it. Seems it works on the later versions and not the early ones. My aftermarket alarm does the windows on the button anyways. Might try it on Briceys car lol
Offline turbokid23
« Reply #8 on: 19 August 2012, 10:45 »
Mines a 2001 Aum and mine does the windows with the key not the fob
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #9 on: 19 August 2012, 13:50 »
If you've got a VAG COM cable give it a go and report back
