Author Topic: how to get the windows to work with fob  (Read 2187 times)
Offline harlemex
Re: how to get the windows to work with fob
« Reply #10 on: 19 August 2012, 13:57 »
Mines a 2001 Aum and mine does the windows with the key not the fob
All mk4 gtis do this. The point is the software should make this work via the fob.  :nerd:
Offline harlemex
« Reply #11 on: 19 August 2012, 14:34 »
It's down to the CCM by the look of it. Seems it works on the later versions and not the early ones. My aftermarket alarm does the windows on the button anyways. Might try it on Briceys car lol
where can one find their ccm?
Offline old_n07
« Reply #12 on: 19 August 2012, 16:42 »
It can be done on all MK4 Golfs as long as they have leccy windows :afro:
The software in the link when used in free mode will ony do the later 1C0 959 799 CCM as found in immo3 cars. If you need to do the earlier 1J0 959 799 AH immo2 CCM then you need to purchase the full version.
Or use VDS pro and edit the HEX values of the CCM manually :afro:
1J0 959 799 AH (UK Spec)
Address
04283 - set 2
04289 - set 2
08628 - add 4 Drivers Side Front
12724 - add 4 Pass Side Front
16820 - add 4 Drivers Side Rear
20916 - add 4 Pass Side Rear
1C0 959 799 B
Address
04361  - subtract 8
04362  - subtract 8
04363  - subtract 8
Neil
Quote from: mikemk4golf
Hey you're a moderator, I want a serious answer not someone who takes the piss!
Grammar is the difference between Helping your Uncle jack off a horse and Helping your Uncle Jack off a horse.
Not so standard Gt TDi
Cluster Mods FAQ | Miles to Empty Guide
Offline old_n07
« Reply #13 on: 19 August 2012, 16:44 »
Take the covers off under the steering wheel and look up past the column behind the fuse box and it is mounted to a bracket, just a plain black box with two or three multi plugs going in to it :afro:
« Last Edit: 19 August 2012, 16:54 by old_n07 »
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #14 on: 19 August 2012, 20:58 »
Neil does VDS pro use the VAG COM or VAG TACHO cables?
I might have to obtain a copy...:afro:
