Author Topic: what should my tickover be ?  (Read 1652 times)
Offline Craigwilson
« on: 18 August 2012, 18:56 »
what should the tickover on a 91 8v sit at ?
Offline Agreeable Slick
  • Unit
Re: what should my tickover be ?
« Reply #1 on: 18 August 2012, 18:59 »
850 - 950RPM
Offline Craigwilson
« Reply #2 on: 18 August 2012, 19:03 »
mines is 840
  • Unit
« Reply #3 on: 18 August 2012, 19:06 »
OK good.
Offline devilscaff
  • allways up for alaugh
« Reply #4 on: 18 August 2012, 20:28 »
Mine is 1000 on an 16v how can I slow it down the idle screw is down as far as it can
Offline Gambit
« Reply #5 on: 18 August 2012, 22:16 »
Sounds like your injector seals are worn and drawing air through them if you cant get the idle any lower than 1k rpm. Good test is with car running spray wd40 down round injector seats, if engine note changes then you know they replaced
950-1000rpm is the correct idle speed for a 16v
Offline devilscaff
« Reply #6 on: 18 August 2012, 23:12 »
Ok cheers have to check when I get chance
Offline Ali MK2 :-)
« Reply #7 on: 12 September 2012, 19:49 »
Mine is a 16v but is set up for the track...idles at 1300? not sure if that's because it has been played with  :undecided:
