Author Topic: Front lower arms upgrade  (Read 1417 times)
Offline 1stevester1
« on: 18 August 2012, 18:31 »
Hi is there an upgrade for the standard ones that you can buy ? Heard tt ones fit with a bit of hassle? Cheers
Offline Steve_PD
Re: Front lower arms upgrade
« Reply #1 on: 18 August 2012, 18:38 »
TT or R32 fit or full on custom tubular upgrades if your loaded
Offline 1stevester1
« Reply #2 on: 18 August 2012, 18:53 »
Not loaded  :sad: so will they fit what's involved here'd it's a faff to get them to fit
Offline Steve_PD
« Reply #3 on: 18 August 2012, 18:58 »
Think you need the hubs and possibly the track rod end :undecided:
Offline 1stevester1
« Reply #4 on: 18 August 2012, 19:10 »
Ooo standard ones it is don't suppose you know what disc fit when you got the 312 upgrade ie tt ones or others as I m replacing them and carnt seem to find a answer
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #5 on: 18 August 2012, 19:24 »
You can get the early TT cast versions that have a provision for the standard drop links, they still need tapping out to accept the bolt first though. These will fit straight on the Golf with no need for the hubs/track rod ends (I've got them on mine)
312mm discs are all the same mate (TT, S3, Anni etc)
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #6 on: 18 August 2012, 19:33 »
oh and they're as rare as hen's teeth
Offline 1stevester1
« Reply #7 on: 18 August 2012, 19:36 »
You got a picture of one so I know whatim looking for  :wink:
Offline Kyle!
« Reply #8 on: 18 August 2012, 21:50 »
Why are you replacing them? If it's due to the bushes you can just upgrade these with TT / LCR ones?
Kyle!
http://uk-mkivs.net/forums/p/473515/3251643.aspx#3251643
^^ Clicky For Build Thread (Updated 17/08/12) ^^
Offline 1stevester1
« Reply #9 on: 18 August 2012, 21:56 »
There gone yeah just easier to replace the whole thing as doing drop links disc pads clutch and full coilovers could you believe that it all went at the same time I have all the luck
