Author Topic: Front lower arms upgrade  (Read 1411 times)
Offline rockmonkey69
Re: Front lower arms upgrade
« Reply #10 on: 18 August 2012, 21:56 »
I had super pro before I upgraded to custom tubular wishbones - I don't know of any other mk4 owner to have gone down this route. But the super pro were a good upgrade from standard - less flex and slop; for most people super pro would suffice.
What is the reason for you changing your wishbones? As mentioned it would be easier and mroe cost effective to change the bushes if they need changing as opposed to buying a standard wishbone with standard bushes.
« Last Edit: 19 August 2012, 11:11 by rockmonkey69 »
Offline 1stevester1
« Reply #11 on: 18 August 2012, 21:59 »
What do you mean replace all the bushes on the wishbone with super pro sorry not good on this where would you get that done and is that replacing the ball joint ?
« Reply #12 on: 18 August 2012, 22:28 »
Not the ball joint. I was referring to the bushes on the wishbones. Super pro is the name of a manucturer of uprated bushings. You can find a garage to fit them for you.
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #13 on: 18 August 2012, 22:28 »
Here are my TT arms mate
Offline 1stevester1
« Reply #14 on: 18 August 2012, 22:30 »
Cheers wazzer and cheers I'll leave that for now and buy some and get done at later stage
