Author Topic: Fire popping exhaust  (Read 5227 times)
Offline gtiballs61
  • Wanted-nearside wing in lp3g(flash red)
« on: 18 August 2012, 11:03 »
Since fitting my de-cat i have(other people behind) have told me that when i change gear(5000rpm +)
the exhaust spits out a flame. :cool:
What damage will this cause,if any?
I have a straight through exhaust with de-cat,pipercross panel air filter and have no engine mods.
I will try get a pic sorted of the popping flame.
It has been running like this for more than 8 months now.I have had no running problems apart from the maf sensor,which i sprayed with some sort of electric cleaner and has been fine since.
Oh and she does run a little rich
« Last Edit: 18 August 2012, 11:07 by gtiballs61 »
VW BUSH
Re: Fire popping exhaust
« Reply #1 on: 18 August 2012, 11:21 »
Over fuelling, damage will be done to valves and rings etc and not your exhaust.
You will be down on power and probably fail an emissions test
Can wreck a cat but this is not a problem for you :grin:
I have this going on at the moment, sounds like a V1 when engine breaking into a corner :grin:
kind of gone too far with a dremmel :lipsrsealed:
Offline Khare
  • The bear that khares
« Reply #2 on: 18 August 2012, 11:43 »
Unless its massively overfuelling it's fine. All engines would spit flames, the thing that stops it is the cat and any silencers in the exhaust, and as you have none then you have flames. If it is overfuelling a lot with strong fuel smells and massive flames then it can wash out the bored and cause damage but that's in extreme cases.
Offline gtiballs61
« Reply #3 on: 18 August 2012, 12:14 »
I don't think it is over fuelling massively.Im not getting any running issues or fuel problems.
Offline Leroy
  • Golf GTI Anniversary 16v
« Reply #4 on: 18 August 2012, 13:00 »
I wish my Golf did that! must look cool!!!
Offline sharki786
  • GOT BOOST??
« Reply #5 on: 18 August 2012, 13:41 »
think mine does the same lol. quick rev to 2k and POP :smug:
bit chavy tho :embarrassed:
*****MK3 Anniversary*****
*****MK4 GTI T*****
Offline stainesy
« Reply #6 on: 18 August 2012, 13:49 »
If yours has no car or any silencers how bloody loud is it?
I removed the middle suitcase box on my black golf just leaving the cat as backbox and it was so boomy inside the car that it made my eyes shake and my vision go blury when driving. I had to change it back after half hour of doing it.
Offline mush
« Reply #7 on: 18 August 2012, 14:02 »
awesome my renault 5 turbo did this when the foot went down, found people tended to back off after that   :grin:
MK2 golf 16v :-)
Offline leigh_harty
  • Audi AGU
« Reply #8 on: 18 August 2012, 14:09 »
My vr is straight through  :lipsrsealed:
Although i cant see it, when i change at the redline it shoots flames out  :evil:
Dont lose your dinosaur!
Gavv8
« Reply #9 on: 18 August 2012, 22:52 »
How can you see your exhaust tailpipe from the drivers seat?
