Author Topic: Fire popping exhaust  (Read 5236 times)
Offline F17BAD
  • Golf MTM S3 GTI TURBO
Re: Fire popping exhaust
« Reply #20 on: 20 August 2012, 22:59 »
He is right...  flames = somethings not right
Not no ordinary GTI....
www.mixcloud.com/kells/
Offline ChowderV4
  • Mk2 2.0 Gti 8
« Reply #21 on: 21 August 2012, 16:42 »
oh i know, i wasnt arguing with that.   :smiley:
luckily mine only glows haha :grin:
Offline paul herbert
« Reply #22 on: 21 August 2012, 20:40 »
been told mine fires out flames on the strip but it is s charged and 100 shot of gas :grin:
Offline sharki786
  • GOT BOOST??
« Reply #23 on: 21 August 2012, 22:50 »
as said before: they only pop when there is no restriction (straight through pipe w/o any silencers or cats) i remember my mate had a straight through pipes (jap style on each side) for his rx7 and boy did that pop
mine pops aswell at 2k revs sounds like thunder (rumbling) :evil:
*****MK3 Anniversary*****
*****MK4 GTI T*****
Offline dom
  • Back in a Mk4
« Reply #24 on: 21 August 2012, 23:57 »
My Mk4 spits the odd flame when booting it, usually when lifting off after a sharp burst of acceleration. It only does this after I got rid of the cat and fitted a 3" turbo back :grin:
Offline Khare
  • The bear that khares
« Reply #25 on: 22 August 2012, 09:42 »
Mine chucks out a small flame sometimes when I hit the limiter. Rumbles and pops at around 1800 if I'm coasting and when I change gear fast.
As said before, too many flames are not good for an engine. It's normal if it's a non restrictive system and it chucks out a small flame when giving it an absolute thrashing.
Offline Rmachines
  • Passat 20vT Estate and Candy White MK3 1.8 GL
« Reply #26 on: 22 August 2012, 17:11 »
The ECU/Engines mission is to achieve stoichiometric combustion at all RPM and load ranges, We all know thats not 100% possible, i don't think it should quite be spitting flames though.   However, its normal to throw fuel down the pipe when on the limiter, as it cuts the spark not the fuel.  But, realistically, it doesn't take much of an over fuel to cause a backfire, and were not talking about "new" lean burn engines here..... so i think to see flames, is kind of "normal" considering the straight through pipe
10 golfs and counting!
Engine cranes = the ultimate tool to test the tensile strength of Everything you didn't disconnect!
Offline sharki786
  • GOT BOOST??
« Reply #27 on: 22 August 2012, 23:14 »
 :cool:
*****MK4 GTI T*****
