Author Topic: Top mount symptoms  (Read 1171 times)
Offline sierragls
Top mount symptoms
« on: 17 August 2012, 19:18 »
How do you know if the top mounts need replacing? I've hit a knock/clunk coming from the front passenger corner every now and again, does it sound like it could be the top mounts?
Gavv8
Re: Top mount symptoms
« Reply #1 on: 17 August 2012, 19:41 »
Most probably top mounts, cheap and relatively easy to change just make sure you drown the top nut in wd40/plusgas for a few days before you start.
Offline sierragls
« Reply #2 on: 18 August 2012, 10:22 »
Ok, thanks for the advice. Just looking on gsf and I see that there are top bearings too, are these worth changing at the same time?
Offline Khare
  • The bear that khares
« Reply #3 on: 18 August 2012, 10:31 »
Go on eBay for the mounts and look for a seller called tierod69. He sells great quality stuff, loads of us use him. And yes bearings too, they come with the top mounts usually.
VW BUSH
« Reply #4 on: 18 August 2012, 11:09 »
Top mounts first then try bottom joint if that don't work :smiley:
