Author Topic: Front driver seat  (Read 2066 times)
Offline Ralphy_GTI
Front driver seat
« on: 17 August 2012, 08:08 »
Need some help guys, Driver seat cover and bottom sponge is damaged but i have new sponges and covers for the seat but i dont know how to remove the front driver seat or the headrest to begin with?
Golf Mk3 GTI - Gone but never forgotten!
Golf Mk4 TDI - Back from the dead!
Offline robo22sri
Re: Front driver seat
« Reply #1 on: 17 August 2012, 08:58 »
If you slide the seat all the way back there is a black pin in the centre underneath that needs pushing together and justs pulls out!
Then push the set back towards the rear bench seat out!
Offline kahunajb
« Reply #2 on: 17 August 2012, 09:15 »
There is a guide somewhere in the maintenance section.
When I did mine I couldn't remove the headrest but you can peel the fabric back and put two slits in the foam below the headrest to remove the old foam and again in the new foam to refit. Once it is all back together you can't tell.
Sorry just reread your post. It's the top half of the drivers seat cover you want to replace? You will need to remove the headrest then but not sure if this is possible. If you have a full donor seat not just the covers and foam you could swap the top half of the seat over.
« Last Edit: 17 August 2012, 09:24 by kahunajb »
Mk1 Leon Cupra TDI - Keeping
Mk5 Golf GTI - Revo Stage 1 - FOR SALE £5,250
Mk3 GTI 16v Anniversary - OEM+ - Gone :(
Mk4 GTI 2.0 - Slow - Good Riddance
Offline sharki786
  • GOT BOOST??
« Reply #3 on: 17 August 2012, 10:14 »
as robo said. After that you need to remove the plastic cap and a long plastic bar (these are on the seat runner). You then slide the seat all the way back and it will pop out.
1ce you have the seat out you need to remove the backrest  adjusting knob (this just pops out) then to remove the black plastic cover you push 2 little pins in (very hard to spot) these are on the bit where the adjusting knob is.pull it of and do same on other side. After you have removed these you will then see the nuts. Remove from both side (i think these is about 4 it) the top half of the seat will drop or pull of.
If i get a chance i will get pics for you.
*****MK3 Anniversary*****
*****MK4 GTI T*****
Offline Hongkongphooey
« Reply #4 on: 17 August 2012, 10:53 »
I've just posted a thread on this in the 'interior' section on this forum
http://www.golfgtiforum.co.uk/index.php?topic=238705.0
I am not technical at all but even I managed this.....
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
« Reply #5 on: 17 August 2012, 14:55 »
This is very informative in regards of taking the seats apart : http://www.golfgtiforum.co.uk/index.php?topic=65964.0
Offline Ralphy_GTI
« Reply #6 on: 21 August 2012, 19:36 »
New seat in ...  :tongue:
Offline kahunajb
« Reply #7 on: 21 August 2012, 20:22 »
Direct replacement with no repairs?
