Author Topic: what are the pros and cons of lowering springs  (Read 1557 times)
Offline luke300586
« on: 16 August 2012, 20:47 »
thinking about lowering my car with springs 30-35mm what are the pros and cons of doing this
Offline dan2252
Re: what are the pros and cons of lowering springs
« Reply #1 on: 16 August 2012, 21:21 »
you can buy new coilovers for 150,160 quid id just buy them as in the long run you will want to go lower as even with a 35 mm drop its still as high as a 4x4
MK4 golf 1.8 turbo agu :)
Offline jamie1989
« Reply #2 on: 16 August 2012, 23:04 »
Honest answer - waste of time buy coilovers. DPM performance have offers £150 delivered on ukmkivs. Job done.
1.6-1.8t AGU K03s, Forge actuator, Forge 007p, turbo back exhuast, Ths front mount, Catch can, 5 piece silicone boost pipes and creation sports tip. Stage 2 atm 232bhp 270lbs. Waiting for custom mapping :-)
Offline luke300586
« Reply #3 on: 17 August 2012, 11:25 »
so whats the lowest and highest i can go on coilovers
Offline dom
  • Back in a Mk4
« Reply #4 on: 17 August 2012, 11:36 »
Pros
- Relatively cheap
Cons
- Paired with standard shocks they will provide a crap ride.
- Shocks will wear prematurely
- Fixed height
- Don't go low enough
- You'll wish you'd bought coilovers
That depends entirely on the coilovers you buy, although most lower ~30-80mm
Offline mcgee9t2
« Reply #5 on: 17 August 2012, 12:47 »
+1 on what doms said.
pros on lowering springs WITH matching shocks
better ride quality than coilovers(less harsh)
depends what you want, few hundred and you could have a really good set of springs and shocks.
400-500 and you could have a really good set of coilys such as weitech ect,
« Reply #6 on: 17 August 2012, 13:57 »
If your going to fit springs then go for a matched spring / shock kit.
Try and avoid cheap coilovers
