Author Topic: clutch slipping even after a new one fitted :s !  (Read 2375 times)
Offline simon_709
« on: 16 August 2012, 17:35 »
Hi guys, when I fitted the new engine to my gti the first time I drove it the clutch was slipping badly, so I just had a nightmare changing it today, went for a drive after the brand new one was fitted and its still slipping?? Does anyone know why? Would it be the flywheel or can the clutch be adjusted at all? Any info much appreciated. Thanks
My Golf GTi, RS4 reps 17", coilovers, tinted windows, De-cat and middle box removed with 3" oval back box, stage 1 Revo re map, G60 flywheel/VR6 clutch, HID kit, Forge 007p,
Offline dan2252
Re: clutch slipping even after a new one fitted :s !
« Reply #1 on: 16 August 2012, 23:25 »
when you fitted the new clutch did you take it out the box and just fit it straight on? as they have oil on them in the box so they dont rust so you should clean them with brake and clutch cleaner first.  if you did clean it.. clutch pedal ok? crank oil seal not leaking? everything fitted back as it come off?
MK4 golf 1.8 turbo agu :)
Offline simon_709
« Reply #2 on: 17 August 2012, 08:45 »
yeah i did clean it before fitting, and i fitted it exactly the same as the old one came off... clutch pedal seems fine as well, and i havent seen any oil leaks. :S  just seems so werid.
Offline Dalo Harkin
« Reply #3 on: 17 August 2012, 08:48 »
mine slipped very occasionally in 2nd after fitting the new one, went away after a few miles
Offline mcgee9t2
« Reply #4 on: 17 August 2012, 12:42 »
yeah ide give it a drive up and down the road a few times see how it is, could just be a little bit of grease or something left on...
unless its slipping really bad?
« Reply #5 on: 17 August 2012, 13:55 »
Are you sure the crank seal was all ok, if it is weeping oil then it will cause the clutch to slip.
Offline mar_k
« Reply #6 on: 17 August 2012, 15:21 »
is the new clutch and pressure plate the sam make as the old one? did you compare new and old as some pressure plates vary in diameter and thickness. For example a Luk kit may be slightly different to the sachs which is another reason its best to buy a complete kit which includes a new DMF
Offline simon_709
« Reply #7 on: 17 August 2012, 17:17 »
is the crank seal near the actual crank itself? i did compare the old and new clutch and they both look exactly the same, and its undrive able because its impossible not to make it slip... so could this be the flywheel? because im tempted to just change that for g60 then put a vr6 clutch on.
Offline mar_k
« Reply #8 on: 17 August 2012, 17:53 »
you would have needed to sit old and new side by side to notice a difference in thickness, the crankshaft seal is behind the fly wheel. did you clean the flywheel with brake/carb cleener,? was ut scored at all? are you sure you fitted the friction plate the right way round? it would have either oben or flywheel side stamped on it
Offline simon_709
« Reply #9 on: 17 August 2012, 18:04 »
yeah i did that and didnt notice any difference, i didnt notice any leaks anyway :S  and the flywheel looked fine and i did clean it before fitting the new clutch, and i did see that said flywheel side etc and double checked it was the right way round.
