Author Topic: Car died this morning  (Read 1278 times)
Offline mrapoc
« on: 14 August 2012, 12:37 »
Hi all. This morning I put my key in the ignition and the dash went dead. Nothing would happen. I also tried locking the car etc. and nothing would happen.
I then had the bright idea to unplug the negative terminal on the battery. The sparks were quite small meaning possible low voltage?
Anyway, hooked it back up and the car started...why did this happen??
« Last Edit: 14 August 2012, 12:42 by mrapoc »
Offline richw911
Re: Car died this morning
« Reply #1 on: 14 August 2012, 12:46 »
Corroded battery terminals?  Loose or broke earth lead?
Offline Nino
« Reply #2 on: 14 August 2012, 12:50 »
Sound like a dead batt? tried bumpping it?
Current - MK6 GTi Edition 35
Offline barrym381
« Reply #3 on: 14 August 2012, 12:58 »
why do that when it started  :grin:
Offline mrapoc
« Reply #4 on: 14 August 2012, 12:58 »
Well it started fine once i reconnected it and I've never had this issue before.
I was worried about starting it after I had stopped at a client's workplace approximately 10 mins drive after the incident but it started fine...
How can I test if it is indeed the battery on its way out? May be related...but my trip computer seems to dim and brighten randomly recently
Offline richw911
Offline mrapoc
« Reply #6 on: 14 August 2012, 13:06 »
I did have a look and they don't look burnt out - or is it something internally?
Lol come to think of it...I do get slow wipers
Offline Xtrhardcore
  • Mk3 Gti 2.0 8v MoreDoor
« Reply #7 on: 14 August 2012, 16:24 »
You should see if you can grab yourself or borrow a volt meter, this would give you a clear indication if its your battery :)
Mk4 Gti - Gone but not forgotten!
Offline dan2252
« Reply #8 on: 14 August 2012, 21:25 »
cars time of the month? mine one day the millage went off and everything on the clocks so i took battery off put it back on and it came back on :)
MK4 golf 1.8 turbo agu :)
Offline mrapoc
« Reply #9 on: 15 August 2012, 11:43 »
Cheers all
I'm going to get my voltmeter across the battery at some point
Also check the earth and then possibly look at the fuse box. It really has started dimming a lot!
