Author Topic: 8v AGG timing.......  (Read 2550 times)
Offline Turbotezz
  • New Dubber
« on: 12 August 2012, 20:49 »
does anyone know what the timing on the AGG should be on VAGCOM live data... I think its block 7, the first reading. I think i have read somewhere it should be between 59 and 62 or 1. Any one know??
Offline Ashy
Re: 8v AGG timing.......
« Reply #1 on: 12 August 2012, 21:00 »
Cant remember off the top of my head but when you plug Vag-Com in and bring up the live data, It will actually show you the parameters it should be between.
Mine was miles out, Just undid dizzy bolt and turned it a little until my reading came inbetween the parameters.
think its between 57-60
Offline Ashy
« Reply #2 on: 12 August 2012, 21:01 »
You get these options in Vag-Com under basic settings 07(For the hall sender)
7,0,Hall Sender DataADY, AGG, AKR
7,1,Hall - Engine Senders,57...60 or 1.0
7,2,Hall - Engine Senders,5...8
7,3,Altitude Correction,0.85 ... 1.15
7,4,Operating Cond.,Throttle 00000000
Offline Turbotezz
  • New Dubber
« Reply #3 on: 12 August 2012, 21:33 »
thanks guys, mine was reading;
Co-ord sender 2 (should be 57-60 or 1)
co-ord sender 9 (should be 5-8)
Altitude correction 0.99 this seems ok
operating cond 0 so does this
So this small amount out must be causeing my pinking!!!!!
Offline Ashy
« Reply #4 on: 12 August 2012, 22:06 »
Yeah it's a tiny bit out. Just turn your dizzy & all will be sorted.
Solved my 5000rpm rev limit & pinking.
Offline Turbotezz
  • New Dubber
« Reply #5 on: 13 August 2012, 20:28 »
my dizzy wont turn!!!!! even with some mole-grips on it!!!!!
This is making me wonder if the peeps who done the cambelt last has put it a tooth out????
Offline Ashy
« Reply #6 on: 13 August 2012, 20:46 »
Did you undo the 13mm (I think) bolt? Mine was easy to turn once that was undone
Offline Turbotezz
  • New Dubber
« Reply #7 on: 13 August 2012, 20:52 »
yep, took the whole clamp off. very strange!!!!
Offline Turbotezz
  • New Dubber
« Reply #8 on: 15 August 2012, 17:22 »
it was just well and truly in there!! Few (gentle) love taps with the hammer and hey presto, the noise that has annoyed me since having the car has gone!! Turned it about 10­° and clamped it back up! checked with the vagcom lite and its now reading from block 7
co-ord sender 1 - 60
co-or sender 2 - 7
altitude correction 1.00
the end one (forgot what it said) 0
Get bloody in!!!!!!!!!!!!!!
Offline Ashy
« Reply #9 on: 15 August 2012, 17:32 »
Nice one mate.
An easy job makes so much difference.
