Author Topic: What turbo is this??  (Read 17657 times)
Offline golfyste
  • Project track car
« on: 12 August 2012, 16:01 »
Alright lads
Post in the or sale thread but am now really confused as its been pointed out to me
I assumed this was a k03s when I took it Off my car but it has the wrong amount blades on the turbine wheel.
It also hasn't got a tag on
This is the info I got off the cold side and hot side casings
Cold side - 5304 101 5160
Hot side -
039060   1262
Nisicr 3532
039060
3532
Any ideas?
Cheers lads
Offline littco
Re: What turbo is this??
« Reply #1 on: 12 August 2012, 16:54 »
Can you measure the inlet bore? Looks like a k04 compressor.maybe a hybrid of some kind. Not a KKK part though...
Offline golfyste
  • Project track car
« Reply #2 on: 12 August 2012, 16:56 »
I will try get some measurements  :smiley:
Offline dan2252
« Reply #3 on: 12 August 2012, 17:19 »
thats werid isnt it? you buy the car standard?
MK4 golf 1.8 turbo agu :)
Offline golfyste
  • Project track car
« Reply #4 on: 12 August 2012, 17:26 »
Ok just had the vernier out  :smiley:
 So up to now info is -
Cold side -
 5304 101 5160
Hot side -
039060   1262
Nisicr 3532
039060
3532
Measurements -
Inlet I.d - 38.8mm/1.528"
Edge of inlet i.d - 39.9mm/1.571"
Inlet O.d 44.9-45 mm / 1.769"
Cold side outlet I.d - 39.9mm/1.571"
11 blades on turbine
10 blade on compresser wheel
« Last Edit: 12 August 2012, 17:30 by golfyste »
Offline golfyste
  • Project track car
« Reply #5 on: 12 August 2012, 17:28 »
Not completely but only a few small mods like exhaust and air filter and a map
But it
Never really run great (about 170bhp)
So may have been mapped before with more mods
Wish I had bought standard tbh
Offline golfyste
  • Project track car
« Reply #6 on: 12 August 2012, 17:35 »
James2 found this....
http://uk-mkivs.net/forums/p/351996/2390179.aspx
So are we thinkin it's a k03 hybrid  :huh:
Offline dan2252
« Reply #7 on: 12 August 2012, 17:47 »
i know how you feel pal! would never buy a pre modded car again, why did you change the turbo?  for more power or was it causing it to run poor?
Offline james2
  • No scammers please.
« Reply #8 on: 12 August 2012, 17:49 »
Looks like it. If my AGU turbo needs a refurb im sending it to them. Might come back with 5 blades instead of 12.  :smiley:
AGU 1.8T. Mods done: R32 front bumper, turborev smic, ngk platinum spark plugs, uprated pancake pipe, demon motorsport boost hoses, forge 007 dv, forge engine cover, r-tec stage 1 map ,home made cold airfilter ,run on 98 ron fuel and castrol edge 0w 40 oil. Advanti racing alloys.
Offline dan2252
« Reply #9 on: 12 August 2012, 18:04 »
would less blades be better ? :)
