Author Topic: werid engine, power issue!  (Read 2454 times)
Offline dan2252
« on: 11 August 2012, 22:59 »
right, my cars been doing this every so oftern and its geting rather anooying now. you'll be driving along under hard power and it will almost throw you through the windscreen like ive jammed brakes on! did it in second gear yesterday and it was that agressive it made the front wheels squeal! cant think for the life of me whats doing it,
 turbo waste gate had seazed up ive now sorted that re checked that and its still free
got 2 faults in engine for, somthing about intake manifold pressure exceeded or somthing, then a mixture too rich fault, but thats due to the blowing exhuast as its blowing just before lambda that wont be the cause as it was doing this before exhuast flexy went.
fitted a new genuine  n75 valve.
checked all vac lines and hoses wiring plugs im running out of ideas only thing i can think of is maybe a airflow meter would this cause this?
any advise guys on what to do?  thanks in advance danny!
MK4 golf 1.8 turbo agu :)
Offline dom
  • Back in a Mk4
Re: werid engine, power issue!
« Reply #1 on: 11 August 2012, 23:43 »
It's called a rev limiter Danny, when the needle goes into the red it means change gear :wink:
« Last Edit: 11 August 2012, 23:48 by dom069 »
Offline jamie1989
« Reply #2 on: 11 August 2012, 23:50 »
LOL
1.6-1.8t AGU K03s, Forge actuator, Forge 007p, turbo back exhuast, Ths front mount, Catch can, 5 piece silicone boost pipes and creation sports tip. Stage 2 atm 232bhp 270lbs. Waiting for custom mapping :-)
Offline dan2252
« Reply #3 on: 12 August 2012, 11:29 »
haha na it aint that dom ahah :) it happends mainly around 5k once its coming onto boost
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #4 on: 12 August 2012, 13:00 »
limp mode, you're overboosting for some reason and the ECU is saving the engine
Offline dan2252
« Reply #5 on: 12 August 2012, 13:21 »
after doing abit of searching found that the air flow meter controls boost on the agu is this true?
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #6 on: 12 August 2012, 13:24 »
yes it does mate. You need to do some logs of the MAF readings, N75 duty etc to see what's going on. It could be over reading which is why it's shutting down
Offline dom
  • Back in a Mk4
« Reply #7 on: 12 August 2012, 13:32 »
Yeah it does, we can try my MAF on yours if you want? It's only a few weeks old & genuine one from your work :wink:
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #8 on: 12 August 2012, 13:39 »
Dom not if yours is AUM and his is AGU...
Offline dom
  • Back in a Mk4
« Reply #9 on: 12 August 2012, 13:53 »
Yup, true that :grin: :rolleyes:
