Author Topic: werid engine, power issue!  (Read 2455 times)
Offline dan2252
Re: werid engine, power issue!
« Reply #10 on: 12 August 2012, 17:24 »
what channels do i need to go into mate? if i can get some print outs of the readings and post them up on here will you know what they should roughly be?
MK4 golf 1.8 turbo agu :)
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #11 on: 12 August 2012, 21:13 »
I'll check what blocks you need. What sort of power should you be running?
Offline dom
  • Back in a Mk4
« Reply #12 on: 12 August 2012, 21:43 »
I think he's got an AGU with KO3s, S3 Fuel Pump, FMIC, APR d/v, 2.5"(?) turbo back exhaust with decat, some kind of performance filter & a remap, so I'd guess 230ish?
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #13 on: 12 August 2012, 21:55 »
say 225bhp as it makes it easier to compare my MAF readings  :laugh:
Try those blocks for starters :afro:
Offline dan2252
« Reply #14 on: 12 August 2012, 23:27 »
sorry for the late reply guys been out, yeah its got front mount, remap, forge tip, apr recirc valve, ko3s, pipe cross pannel filter, s3 fuel fuel pump, 2.5 turbo back exhuast, will find out exact power in a few month when she goes on the rollers!  im gonna say power is going to be 200, 230 as its still on standard agu injectors at the moement.
il get some logs up asap what did you do then go for a drive taking it round the revs under full power? and just take snap shots of whats on the screen? :)
thanks for you help so far lads!
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #15 on: 12 August 2012, 23:39 »
go to measuring blocks, select 002, 003 and 025 then start recording the logs, full throttle 3rd gear run from around 2k to redline
it will save the log file in the Program files -> VAG COM folder. Open this in excel and have a looksie :wink:
Offline dan2252
« Reply #16 on: 12 August 2012, 23:46 »
il have to borrow vag com off lad at work. as i dont think our vw software will let us get in that far :) thanks for all the help though pal! :)
Offline dan2252
« Reply #17 on: 14 August 2012, 18:44 »
right guys ive not managed to do vag com logs but used our computer at work to get rough readings just for now, the n75 load when you floor it in 3rd goes straight to 99 percent then fades off to 63 percent to the red line, and channel 002 i belive was giving me a reading of 176.4 g/s at 5600rpm thats all i could do for now lad at work forgot to bring his vag com :( so is that about right? sorry the readings are so vauge it was hard trying to balance computer and freeze frame the screen haha
Offline dan2252
« Reply #18 on: 14 August 2012, 21:26 »
also is it true you can work out the rough bhp from your air flow meter readings? is the a guide how too? :)
