Author Topic: NaiL in tyre  (Read 2168 times)
Offline pisquano
NaiL in tyre
« on: 11 August 2012, 20:19 »
Hi everyone
Noticed my rear left was losing pressure substantially. Looked down there is a big nail stuck which is letting air out.  :angry: :angry:
It's annoying also because the tyre is in perfect condition otherwise (Michelin ps3).
Would you change just that one or the other rear one at the same time? I'm asking because I normally change all 4 and never ever had a puncture.
I wouldn't want the car to drive strange with 1 new tyre and the others not (although only 1 year old)
Thanks
Fed
ad maiora
previously: Toyota Celica 1.8, Mini Cooper S (supercharged), Audi RS4 avant (B7) - currently Golf GTI Ed30 silver
Offline bacillus
Re: NaiL in tyre
« Reply #1 on: 11 August 2012, 22:32 »
Depending on the nail's position, a repair may be possible...
Without traction power is nothing!
Offline Mr GTD
Re: NaiL in tyre
« Reply #2 on: 11 August 2012, 22:56 »
Get to your nearest tyre specialist and they will tell you if it's repairable...
Offline crimsonfin
Re: NaiL in tyre
« Reply #3 on: 13 August 2012, 13:22 »
you should be looking at something in the region of £20 to get it fixed (if it is repairable)
Offline pisquano
Re: NaiL in tyre
« Reply #4 on: 13 August 2012, 13:24 »
thanks will go there tomorrow morning.
hopefully it can be repaired. seems to be in the "repairable" area of the tyre....let's hope so
ad maiora
Offline Rhyso
Re: NaiL in tyre
« Reply #5 on: 13 August 2012, 14:22 »
Its its in the 'meat' of the tread then it should be repairable.
The closer the puncture is to the sidewall the less likelihood of it being repairable
Offline pisquano
Re: NaiL in tyre
« Reply #6 on: 13 August 2012, 14:41 »
it's not on the sidewall, but stuck into the undertread rather than the tread, why I am a bit suspicious it can be repaired
ad maiora
Offline Gti_Jamo
  • 1991 Corrado 1.8 G60
Re: NaiL in tyre
« Reply #7 on: 13 August 2012, 14:46 »
Anything in the centre 3/4's of the tread can be repaired as long as its not too big a hole. If its just a screw and within the limits it will be repaired no problem.
Offline Turbotezz
  • New Dubber
Re: NaiL in tyre
« Reply #8 on: 13 August 2012, 21:29 »
should be repairable. The size of the patch on the mushroom is about 3" dia. Take it to a fast fit place, they will tell you. Kwik fit is £22.50 for repair, new valve and balance. A repair will not change the performance of the tyre dude
