Author Topic: Wheel bearings...?  (Read 1486 times)
Offline sveed1.8T
Wheel bearings...?
« on: 10 August 2012, 21:15 »
Pretty sure my rear drivers side needs replacing, as it's sounds like a tumble drier when I'm on the motorway! :laugh:
Question's: Is it worth saving a few pennies with forum discount n buying from ECP rather than dealers?
Is it worth doing both sides at the same time?
Not including parts, what sort of price am I looking at for the job?
Thanks in advance :smiley:
Offline Steve_PD
Re: Wheel bearings...?
« Reply #1 on: 10 August 2012, 21:27 »
Buy at ECP's
No need to do both sides.
Got tools? Do it at home. No special tools needed its a piece of piss to fit and will take you an hour.
Garage should charge no more than an hour.
Offline sveed1.8T
« Reply #2 on: 10 August 2012, 22:06 »
Buy at ECP's
Diamond! :wink:
I prefer doing jobs myself if I can... Roughly what's needed?
Offline Steve_PD
« Reply #3 on: 10 August 2012, 22:13 »
Remember now you need a puller or a grinder and chisel to get the inner race of the bearing off apart from than its just spanners and a socket set.
Offline richw911
« Reply #4 on: 10 August 2012, 22:26 »
Offline sveed1.8T
« Reply #5 on: 10 August 2012, 22:40 »
I always thought that with bearings, you needed a press? :huh:
Sure its not the rear tyres.......
http://www.golfgtiforum.co.uk/index.php?topic=92328.0
It's def not that. For one, the tread is even, n two, I hear it at all speeds, with the pitch increasing the faster I go. Cheers for the suggestion though Rich :smiley:
Offline Steve_PD
« Reply #6 on: 10 August 2012, 22:46 »
No I never used a press to get in back on
Offline Kyle!
« Reply #7 on: 13 August 2012, 22:27 »
U need a press for the front ones as they're pressed into the hubs  :wink:
http://uk-mkivs.net/forums/p/473515/3251643.aspx#3251643
^^ Clicky For Build Thread (Updated 17/08/12) ^^
Offline Steve_PD
« Reply #8 on: 13 August 2012, 22:35 »
Yes but he's asking about the rear ones. Plus you can use a vice to press the front ones in. Done both my front ones fine using a vice and a chisel to smash the inner race off.
Offline sveed1.8T
« Reply #9 on: 14 August 2012, 00:06 »
I had a look on ECP n the rear bearings that they sell are with the hub for £60 odd. I thought you could just buy the bearing itself? :huh:
