Author Topic: ABS problem  (Read 1098 times)
Offline stu646
ABS problem
« on: 09 August 2012, 18:04 »
Around 3/4 weeks ago my abs light came on. I thought it was just a faulty sensor as had no end of problems with them on my old MK3.
Couple of days ago they abs light turned off, but this is when the problems start. When I apply the brake pedal I get no end of judder/vibration and noises. I guess this is the abs kicking in when it is not suppose to?
When the abs light comes back on, which it does every now and then, the judder/vibration goes away again.
Will it just be the sensor that is the problem?
Offline Toby
  • Car - less
Re: ABS problem
« Reply #1 on: 09 August 2012, 19:32 »
Check the fuses ontop of battery.  :cool:
Currently down under
Offline stu646
Re: ABS problem
« Reply #2 on: 10 August 2012, 14:45 »
They are all good!
Offline stu646
Re: ABS problem
« Reply #3 on: 17 August 2012, 10:42 »
Still having problems with this.
Asked the dealers if they could run a Vag-com check, £65!! Sod that
Anyone round Manchester way with a Vag-com do it cheaper?
Offline GTi_James
Re: ABS problem
« Reply #4 on: 17 August 2012, 10:58 »
locals could charge between 15 and 40 however cash in hand and they probably wont apply vat if you ask nicely  :wink:
Offline stu646
Re: ABS problem
« Reply #5 on: 17 August 2012, 11:00 »
Would a vag-com tell us what the abs light is on for though? Or would I be better off just putting the car in the local garage to be fixed. As at the moment, the abs seems to be kicking in every single bloody time I break
Offline dom
  • Back in a Mk4
Re: ABS problem
« Reply #6 on: 17 August 2012, 11:38 »
If there is a fault with the ABS then it will be logged and scanning with Vagcom will identify it.
Don't book it into a garage without having it scanned first - I'm sure there must be a forum member near you with vagcom?
Have a look here to find out:
http://www.golfgtiforum.co.uk/index.php?topic=87936.0
