Author Topic: Can run flats be fitted to non run flat wheels  (Read 4117 times)
Offline golf-sib
  • Турботазик
« on: 06 August 2012, 22:15 »
Quick question, I can get hold of some cheap part worn  run flats for my current wheels, but will they fit. I can't seem to find a sensible answer apart from they are not recommended as you may not know when you have a puncture as no tire monitoring pressure system exists on cars that initially never had run flats. My car is hardly used and its only a precaution measure to get some cheap tires for the mean while till I can get something in a few months time.
Thanks for any answers in advance  :smiley:
EDIT:
Quote
Thats my understanding Toby, I'm sure it cannot fail an MOT either, think you just get an advisory as well from reading this?:
http://forums.motester.co.uk/forum3/2076.html
Any more light on info is highly appreciated, especially the MOT Side
« Last Edit: 06 August 2012, 22:31 by golf-sib »
VW Golf - k03 AGU - 200BHP
1.8T AGU..
R135
  24
Offline Toby
  • Car - less
Re: Can run flats be fitted to non run flat wheels
« Reply #1 on: 06 August 2012, 22:24 »
Dont they just have hard aidewalls?
Currently down under
Offline Turbotezz
  • New Dubber
« Reply #2 on: 07 August 2012, 09:00 »
simple answer is no. Plus they cost a hell of a lot, and once you get a puncture, they are scrap!
Offline golf-sib
  • Турботазик
« Reply #3 on: 07 August 2012, 09:40 »
uk-mkivs.net/forums/p/424883/2908765.aspx
You sure they won't fit, I can get 4xrunflats for £80 with 4mm tread. Plus I see a mk4 on piston heads with runflats on normal rims?
You get the extreme answers with runflats, its either yes - but at a risk due to no tire pressure system or at the other end its nope, they won't fit at all! I am completely baffled. As a temp measure I'd be happy with them and if they flop from a puncture I'll get a new pair to replace accordingly.
Any more views?
1.8T AGU..
R135
  24
Offline golf-sib
  • Турботазик
« Reply #4 on: 07 August 2012, 10:45 »
Spoke to two tyre places this morning and both have said runflats will fit onto non runflat rims with no problem. Interesting as mr internet seems to have a generic answer of, no, you cant and only a 20% answer rate of yes you can.
1.8T AGU..
R135
  24
Offline Turbotezz
  • New Dubber
« Reply #5 on: 07 August 2012, 17:31 »
I fit tyres for a living. Run flat wheels have a different bead seating area than normal wheels for normal tyres
Offline golf-sib
  • Турботазик
« Reply #6 on: 07 August 2012, 17:43 »
I was told this, but apparently you can still get a run flat on a normal rim?
1.8T AGU..
R135
  24
Offline Turbotezz
  • New Dubber
« Reply #7 on: 07 August 2012, 20:34 »
You would probably get them on, but they wouldn't work as a run flat, the bead would pop off. Run flats are designed so that you can still drive for around 200 miles at no more than 50mph.
Offline golf-sib
  • Турботазик
« Reply #8 on: 07 August 2012, 20:44 »
Thats good to hear as I'll always have a spare :)
1.8T AGU..
R135
  24
Offline Felton
« Reply #9 on: 07 August 2012, 22:05 »
I used to be a tyre fitter and used to have run flats on a old rover I used to own and never had any issues just aslong as you keep a eye on them and if you're only using as a temp measure wouldn't be a prob but as said once u have a puncture they are scrap as you can not repair them and also you can buy cheap tyre sensors that go in normal alloys if your really worried
