Author Topic: Fekked driveshaft bolt?..and various other questions....  (Read 4331 times)
Offline nightroamer
  • Mk3 16v
Guys I'm sure this has been asked befored, I've had a search.
Some previous *lovely* person has rounded a driveshaft bolt on my project car.
Tried the usual hammer and chisel to no avail, any ideas how I can get it out?
I have NO power in my garage also  :cry:
« Last Edit: 19 August 2012, 17:54 by nightroamer »
Offline Jimmyrallye
  • 20vt goodness
Re: Fekked driveshaft bolt
« Reply #1 on: 05 August 2012, 22:59 »
Have you tried getting a pair of mole grips on it has workec for me before
Offline Mr Blue
« Reply #2 on: 06 August 2012, 01:43 »
I tightened the rest then smacked another sized torx bit in there. That got it out! :evil:
I know you have no power in the garage but another way is to dremel the sides of the bolt flat and use a spanner to twist it out.
Offline Diamond Hell
  • Opinions я Us
« Reply #3 on: 06 August 2012, 13:55 »
Molegrips, or a slightly different sized bit smashed in there should sort it.
Offline tomp
« Reply #4 on: 06 August 2012, 21:05 »
You can hammer a socket over the outside of them, should come off no problem and you can tighten them back up using the same method. Top tip is put a load of extension bars together and undo/tighten from inside the wheel arch, makes it much easier...
« Last Edit: 06 August 2012, 21:11 by tomp »
Offline Dolly
« Reply #5 on: 06 August 2012, 21:08 »
you need these in your life
http://www.amazon.co.uk/dp/B000QW6K8I/?tag=hydra0b-21&hvadid=9550948989&ref=asc_df_B000QW6K8I
 they come in 2 sets, on set you get the box. they also do a big f**k*r set which ive got but rarely used.
it still amazes me at what they will grip and undo, worth £20 all day long
Offline tomp
« Reply #6 on: 06 August 2012, 21:14 »
I second that, I have got a snap-on set of these and they are brilliant, they can really get you out of trouble!
Offline Dolly
« Reply #7 on: 06 August 2012, 21:52 »
snap on tried to sell me these last week, he was gutted when i said i had the excate same ones, he didnt believe me until i showed him, had mine for around 4-5 years now so they have had some use, got me out the sh!t many a time
Offline SoundillusioN
« Reply #8 on: 07 August 2012, 00:13 »
I need to get myself some of these bad boys.
Offline Dogbot
« Reply #9 on: 07 August 2012, 17:28 »
I used to break bolts fairly regular (i used to be a hamfisted loonatic) bought a set of these along with some patience that was on special offer & never ever had to use em pmsl... but they are there.. just in case....
