Author Topic: cabrio roof not working  (Read 6285 times)
Offline vw_golf_nutter
« on: 05 August 2012, 19:29 »
hi again,
sorry last question, i wouldnt keep asking if you wernt such a knowledgeable bunch!
my mk3 cabrio has an electric roof but it isnt working.
should it be possible to put it up and down without the electric working? currently it wont open manually, didnt know if its just stiff but didnt want to break it.
also any ideas where to start and where the motor is located?
thanks again!
Offline andy-gti84
  • lowanslow
Re: cabrio roof not working
« Reply #1 on: 05 August 2012, 20:04 »
try fuse first mate an think motor is in the boot not 100% tho as never had one.
Offline 67buggers
« Reply #2 on: 05 August 2012, 20:17 »
Pm dubstar9 he had a roof issue and sorted it pretty easily I think
I fix iPhone's and iPod's, I can fix most faults call me on 07811344816 for a quote
« Reply #3 on: 05 August 2012, 20:19 »
If you check the manual, I am sure you need to open a bleed screw first before raising it manually
« Reply #4 on: 05 August 2012, 20:43 »
ok thanks, will send a PM, unfortunately dont have the manual but will see if i can find anything about a bleed screw on google. fuse is a good start - would certainly same me some time if its that! thanks
Offline dubstar9
  • Back to the Golf scene
« Reply #5 on: 06 August 2012, 07:16 »
The motor is located in the passenger side of the boot behind a plastic panel, you should never operated the roof manually as you could pop a ram seal.
PM send :wink:
« Reply #6 on: 06 August 2012, 13:16 »
have PMd dubstar9 but if he doesnt get it before i get down to my local motor factors i just wanted to know if im going in the right direction...
i have tested the 2 red wires that go into the relay, one red wire has a current going through it with the ignition on and off and one doesnt have a current at all. does the current go in through one red wire and out the relay with the other one therefore pointing at the relay being at fault?
if you touch the red wires together with the ignition on the pump makes noise, guessing this is a good thing?
where do i go from here? new relay?
Offline dubstar9
« Reply #7 on: 06 August 2012, 13:30 »
You also need to see if there is a live feed from the dash switch in both directions, press the switch down and one wire will become live, press it up and another wire will become live. These wires switch the main lives in the relay, from the relay you have a thick red wire and a thick black, these reverse live and negative to power the motor in one direction (up) and then in the opposite direction (down).
If you already have the main battery (ignition) live, thick red into relay and lives from the switch in up and down directions and the connections under each side trim panels are plugged in then I think you relay isn't switching and not feeding to motor. If you have bridged the thick red wires and the motor powered up then the motor is fine, try bridging the thick red in and the thick black out to see if the hood moves back.
Keep going, your getting there :wink:
PM'd you this also :smug:
