Author Topic: std boost pressure  (Read 3205 times)
Offline dstv
Re: std boost pressure
« Reply #10 on: 06 August 2012, 16:47 »
I just spoke to Ben at R-Tek and he said the fault could be because I have T'ed off from the pipe above the Dv and into my boost gauge that could be causing it... Does this sound right??
2000 GTI 1.8t AGU, neuspeed airfilter,Forge 007 dv, R-tech stage 1 remap, Silicone TIP,3" exhaust system, K03s turbo and a empty wallet.
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #11 on: 06 August 2012, 18:39 »
try it and see  :wink:
Offline dstv
« Reply #12 on: 06 August 2012, 19:05 »
thanks for the help. Its going back to the place who fitted my boost gauge so they can fit my new boost gauge :grin: on Thursday....
Offline dstv
« Reply #13 on: 11 August 2012, 10:38 »
Hello again,
 I have another question regarding the boost gauge..I bought a digital boost gauge and fitted it yesterday,,looks mint,,
Now driving normal my boost figure is for example -7 psi to -5 and when I put my foot down....it go's up to 6 to 7 psi...does this mean im running at 7psi or 14 psi boost...Im back at R-Teck next week for a check up on my remap but I don't want to look a idiot with them..thinking im not getting the right boost pressure...
Thanks
Eugene
Offline cullygti
« Reply #14 on: 11 August 2012, 10:44 »
if its holding at 7psi then thats what your boosting to it will sit at minus on idle think most ppl including mine sit at around -18-20 on idle but i then boost to around 18psi and hold at 14-15psi thats on my stage 1 map
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #15 on: 11 August 2012, 10:55 »
what is the figure on tickover mate. -7psi is -15 in hg which is about right for normal driving.
Any car runs on vacuum (minus figures) with normal driving. It's only when you reach 0 do you start to read boost (positive figures)
Offline dstv
« Reply #16 on: 11 August 2012, 11:19 »
ok thanks guys....thats good to know..very helpful information
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #17 on: 11 August 2012, 11:41 »
what does the gauge read on idle?
Offline Dalo Harkin
« Reply #18 on: 14 August 2012, 08:55 »
Mine sits at -8 on idle and boosts to 1.1bar (16psi) and thats on a K03 carbon map
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #19 on: 14 August 2012, 18:24 »
Does yours read - psi or - in hg?
