Author Topic: std boost pressure  (Read 3217 times)
Offline dstv
Re: std boost pressure
« Reply #20 on: 14 August 2012, 20:09 »
mine is in PSI but I can set it to Bar
2000 GTI 1.8t AGU, neuspeed airfilter,Forge 007 dv, R-tech stage 1 remap, Silicone TIP,3" exhaust system, K03s turbo and a empty wallet.
Offline Prawny
  • R-tech power!!!
« Reply #21 on: 15 August 2012, 08:47 »
Something's wrong with that. Vacuum on idle doesn't sound high enough, and boost is clearly miles off.
Either a massive leak somewhere, or something electrical stopping boost, AND a leak effecting vac on idle.
The engine HAS to be producing vacuum on idle, so it's most likely the leak will be on the line you have T-d into.
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #22 on: 15 August 2012, 12:27 »
Mine sits at around -22in hg on idle when warm
