Author Topic: Clutch possibly gone?GUTTED  (Read 1340 times)
Offline Leebob
  • Jetta Sport TDI cr170,Mk3 Colour Concept 8v
« on: 04 August 2012, 09:34 »
Right,so the past few days ive been driving i have felt this kind click when pressing down the cluth pedal.Pulled into a garage yesterday to get some new rubber fitted to a set of rims and it finaly went completly.The pedal stayed to the floor :shocked:  :sick: Thinking the clutch had gone.Then found out that the clip that retains the cable on to the lifter arm had come off as it had worn out,managed to fabricate another to do the job but when i tryed to drive off again the pedal clicked again and just went loose.Could this just be a problem with the cable and way it adjusts?
« Last Edit: 04 August 2012, 10:49 by Leebob »
Offline Rmachines
  • Passat 20vT Estate and Candy White MK3 1.8 GL
Re: Clutch possibly gone?GUTTED
« Reply #1 on: 04 August 2012, 11:36 »
These have the auto adjuster ratchet on the gearbox side, its inside that rubber boot on the cable,  if these get pulled tight, they often lock up, or refuse to adjust,  when it comes new, there is a plastic clip that keeps it done up, then you fit and release and it will find its position, so i would have said when the clip came out, it pulled the ratchet tight and now its either stayed tight, or not correctly adjusting.
You can try removing the cable from the box side, then using the clip that comes on the adjuster, if its still there, lock the adjuster up tight, then refit, and release, then pump the pedal a few times, it should adjust,  but i recon that clicking you hear is the adjuster slipping or locking.
10 golfs and counting!
Engine cranes = the ultimate tool to test the tensile strength of Everything you didn't disconnect!
Offline Leebob
« Reply #2 on: 04 August 2012, 11:49 »
That doesnt sound too bad then,at least its sounding like the whole clutch doesnt need replacing.The car is at the garage now and there gonna sort it out monday hopefully.
Offline Rmachines
« Reply #3 on: 04 August 2012, 12:05 »
cool, let us know how you get on,  cant see it being the clutch its self to be honest.
Offline boneybradley
  • Back in a Mk3...
« Reply #4 on: 05 August 2012, 14:00 »
there is a ratchet that sits on the clutch release arm and these commonly snap, remove the green cap on the gearbox side and take the arm out.
they also do snap where there hidden so remove is usually needed to check
and finally replace the cable as they never seem to be right after being fully adjusted
Offline Leebob
« Reply #5 on: 06 August 2012, 19:21 »
Got this fixed today at my local VDub Specialist.Total cost £96.28
