Author Topic: lower strut mount bolt help?!  (Read 3412 times)
Offline Xtrhardcore
  • Mk3 Gti 2.0 8v MoreDoor
« on: 02 August 2012, 12:22 »
Trying to get the strut out the front, and i cant remove the bloomin bottom bolt?!
I have one side off, any ideas how to get the actual bolt out?
I've tired smashin it out, getting a wrench on it and twisting  but its not moving...
any ideas?
Mk4 Gti - Gone but not forgotten!
Offline dom
  • Back in a Mk4
Re: lower strut mount bolt help?!
« Reply #1 on: 02 August 2012, 12:42 »
Get a bit of heat on it and then get angry with a hammer :grin:
You could also try jacking the hub up a little to relieve any pressure on the bolt - I'm not sure that there should be any as the bolt just slips through, but it'd be worth a try.
Offline Xtrhardcore
« Reply #2 on: 02 August 2012, 12:57 »
i am right in thinking it should just pull out? i dont have to undo it?
Offline DunnDeal12
  • Limited
« Reply #3 on: 02 August 2012, 13:00 »
what nut are you on about? the one that connects the strut to hub via a 19mm bolt and nut?
Offline golfyste
  • Project track car
« Reply #4 on: 02 August 2012, 13:45 »
Get a 1/4" drive ratchet and slot it into the gap aroun the back of te strut and turn it a 1/8 of a turn will will loosen te strut a little then wiggle it and hit te bolt  :smiley:
Offline Xtrhardcore
« Reply #5 on: 02 August 2012, 14:18 »
Tried it all being stubborn! Given up lol, spent 5 hours trying to get the strut out!
Offline dom
  • Back in a Mk4
« Reply #6 on: 02 August 2012, 15:07 »
Once the nut is off the bolt should just pull out. Once that is out you have to use a hub splitter tool to open up the bottom of the hub enough to allow you to remove the strut
Offline golfyste
  • Project track car
« Reply #7 on: 02 August 2012, 16:15 »
.....1/4" ratchet  :grin:
Works the same  :tongue:
Offline dom
  • Back in a Mk4
« Reply #8 on: 02 August 2012, 17:19 »
 :grin: I was just trying to clarify it
Offline Xtrhardcore
« Reply #9 on: 03 August 2012, 00:21 »
Yeah it was just the bolt, managed to get the nut off fine but the bolt just would not budge!
Gunna try again soon, maybe get some heat on it.
