Author Topic: What's the lowest you can go on standard shocks??  (Read 1881 times)
Offline rfn_hodgson
Hey lads what's the lowest you can go on standard shocks fitted with lowering springs?? Or the alternative seriously what are those JOM coilovers like??
Thanks in advance??
VW Golf MK4 1.8 Turbo AUQ 203 BHP-more now :) , ultimate vacuum delete, Forgre 007p-new piston, Oil catch can, s3 boost set up, FMIC, silicone TIP, full turbo back exhaust, stage 1 map, lowered on V-maxx coilovers  audi tt Quattro alloys
Offline rfn_hodgson
Re: What's the lowest you can go on standard shocks??
« Reply #1 on: 31 July 2012, 19:27 »
Sorry forgot to add is it in your opinions ok/durable/ wise lol to use the springs??
Cheers again
Offline cullygti
« Reply #2 on: 31 July 2012, 19:27 »
jom are ok for the money but if you can afford it get summat a bit better they are ok for budget lows i aint reall had any probs with mine but wouldnt mind a better set if im honest
i went for 40mm springs on standard shocks and it wasnt low enough for me as i wanted a bit more
Offline rfn_hodgson
« Reply #3 on: 31 July 2012, 19:31 »
Cheers cully... So no dramas then... Hmm yes money is an issue at the moment trying to save but it's driving me insane so I thought a lil shopping for the AUQ wouldn't do any harm lol
Offline cullygti
« Reply #4 on: 31 July 2012, 19:38 »
if going down the spring route just replace the top mounts and bearings same if you get the coils to  :smiley:
Offline dom
  • Back in a Mk4
« Reply #5 on: 31 July 2012, 21:15 »
I ran 30mm springs on standard shocks for a few weeks and the ride was awful, the car felt really unsettled in the corners so I replaced them with JOM coilovers and have never looked back.
« Reply #6 on: 31 July 2012, 22:13 »
Around 35mm but the shocks will not last long so your better fitting a matched kit instead of doing the job twice.
Offline cullygti
« Reply #7 on: 31 July 2012, 22:15 »
na i dont believe that i went 40mm with no probs at all for well over a year not even a rub on the arb there seems to be a lot of old wives myths on here but not enough ppl actually trying it first just to add my shocks were still original parts so 14 year old  :wink:
« Last Edit: 31 July 2012, 22:22 by cullygti »
« Reply #8 on: 31 July 2012, 22:24 »
Standard shocks are designed to work at standard height, lowering springs fitted will shorten lifespan.
Offline cullygti
« Reply #9 on: 31 July 2012, 22:30 »
i dont doubt it at all im saying i never had any probs luck of the draw i suppose  :smiley:
