Author Topic: Turning Off Daytime Running Lights - MFD Problem  (Read 11784 times)
Offline MK6-Fan
« on: 31 July 2012, 19:16 »
Guys, looking for a bit of help please.
In my Golf 'Match'. on the MFD screen I am not able to disable/turn off the daytime running lights that way............is there another way I can do this & is it even possible?
I was able to do it on a 2012 GT that I hired not too long ago.
Thanks
2012 Golf MK6 Match 3dr|1.4 TSI 122PS|Manual|Solid Black|MFSW|RCD510|
Offline SRGTD
Re: Turning Off Daytime Running Lights - MFD Problem
« Reply #1 on: 31 July 2012, 19:30 »
Thanks
Try this - reply no.3 in the thread; link below.
http://www.golfgtiforum.co.uk/index.php?topic=115336.msg1008466;topicseen#msg1008466
Gone but not forgotten;
2016 Polo GTI; Blue Silk
Offline MK6-Fan
« Reply #2 on: 31 July 2012, 19:33 »
That's good advice thanks, but I would maybe like the option at some point in the future to turn the DRL's on again but the reply on the page you quoted says this is not possible to reverse the action.
Offline Raffe
« Reply #3 on: 31 July 2012, 19:40 »
Turned mine off as they looked gash  :sick:
Offline MK6-Fan
« Reply #4 on: 31 July 2012, 19:42 »
 :grin:  :grin:
But how??
Offline Raffe
« Reply #5 on: 31 July 2012, 19:53 »
Are you winding me up :undecided: :grin:
As per the instructions in the link above.
Offline Buck
  • Das Auto
« Reply #6 on: 31 July 2012, 20:00 »
I've had mne turned off that way and they do turn back on again
Deactivating the daylight running lights - Page 62 Mk6 manual
Light switch to 0, Move the turn signal and main beam lever both down and to the rear (left-hand turn signal and headlight flash) at the same time and hold it in this position.
Turn the ignition on for 3 seconds and then switch it off again. The daylight running lights function is deactivated and cannot be switched on again.
Offline p3asa
« Reply #7 on: 31 July 2012, 20:00 »
Raffe, some folk need to be spoon fed obviously  :laugh:
To turn them off.
Do a left hand turn with the indicators and pull back on the stalk to flash the headlamps then turn the ignition on. After a few seconds you should hear a couple of bleeps then they are off.
Do the opposite to turn them off
To turn them on.
Do a right hand turn with the indicators and pull back on the stalk to flash the headlamps then turn the ignition on. After a few seconds you should hear a couple of bleeps then they are on.
Offline SRGTD
« Reply #8 on: 31 July 2012, 20:03 »
And another;
http://www.golfgtiforum.co.uk/index.php?topic=187595.msg1752711#msg1752711
Found this and the previous thread easily by using the 'search' function; there's lots of really useful information out there, and a good chance subjects such as this have been covered before, so worth trying the search facility first.
Also try Google; 'deactivate DRL Golf mk6'. You'll find some links to videos on YouTube.
Offline Rislar
« Reply #9 on: 01 August 2012, 17:20 »
Oh thanks for this, bloody hate them on mine  :smiley:
