Author Topic: Turning Off Daytime Running Lights - MFD Problem  (Read 11792 times)
Offline Jimble
Re: Turning Off Daytime Running Lights - MFD Problem
« Reply #10 on: 01 August 2012, 17:50 »
Raffe, some folk need to be spoon fed obviously  :laugh:
To turn them off.
Do a left hand turn with the indicators and pull back on the stalk to flash the headlamps then turn the ignition on. After a few seconds you should hear a couple of bleeps then they are off.
Do the opposite to turn them off
To turn them on.
Do a right hand turn with the indicators and pull back on the stalk to flash the headlamps then turn the ignition on. After a few seconds you should hear a couple of bleeps then they are on.
^Exactly this but make sure the light switch is in the "off" position as it won't work in auto.
Offline Keithuk
« Reply #11 on: 01 August 2012, 17:50 »
You can't disable/enable the DRL's on 2012 Golfs without VCDS.
2010 Golf GTD (170) CBBB, 5 Door, Shadow Blue (P6/D5Q), Flat Tyre Indicator, Basic Protection Pack + VCDS.
