Author Topic: coolant leak problem  (Read 3279 times)
Offline oceanic-green
  • Mk4 1.8T Aum 260+ Bhp 273 TQ
« on: 31 July 2012, 14:16 »
I have pink fluid over my gearbox, which seems to be coming from the corrugated pipe shown in the picture with the green arrow. How do I go about fixing this? I have never fixed coolant pipes before, only boost and pcv pipes.
http://s878.photobucket.com/albums/ab347/Darrenscriven/?action=view&current=turbo011.jpg
Thanks
« Last Edit: 31 July 2012, 14:18 by oceanic-green »
Mods: R-Tech custom remap, Beachbuggy K250 Turbo, Forge 007 DV, RAMAIR Jetstream 108 induction filter, silicone piping throughout, R-Tech Supersize TIP, 42 Draft Stealth Catch Can, N249 bypass, Ported Manifold, Toyo Sports FMIC with 2 & 1/2 pipes, Custom made full turbo back exhaust & 2 & 1/2 " downpipe and 200 cell sports cat. BAM injectors, Turbosmart Boost Gauge, BBS CK Wheels, 312mm Brembo front discs and pads, Carbon canister delete and last of all, a liquid cube!
Offline harlemex
Re: coolant leak problem
« Reply #1 on: 31 July 2012, 15:18 »
dont think its coming from the corregated pipe, thats wiring in there.
Offline ian007miles
« Reply #2 on: 31 July 2012, 16:10 »
Ive got a coolant leak in the same area lol I think it's the rubber O ring in the plastic bit that bolts to the head where all the water pipes go to in that area
Agu|k03s|forge 007 dv|forge boost pipes|forge water pipes|forge tip|forge kona cold air intake|milltex 3" down pipe sports cat|milltek cat back exhaust|r-tech custom remap 238bhp and 235 torque
Offline Dalo Harkin
« Reply #3 on: 31 July 2012, 17:06 »
+1 itll be from somewhere near it and getting splashed onto it, check where the sender is and surrounding area
Offline Nino
« Reply #4 on: 31 July 2012, 23:20 »
Im assuming you have a 1.8T?
If so it sounds to me you have a leak from your Thermo area, the rubber ring sounds like it could of failed, check where the thermo goes and see if you can see anything.
Current - MK6 GTi Edition 35
Offline Dalo Harkin
« Reply #5 on: 01 August 2012, 00:07 »
its the other side of the block mate  :wink:
« Reply #6 on: 01 August 2012, 09:17 »
I thought it was, as I had it changed about 3 months ago.
Must be some pipe that is split above the corrugated plastic pipe then, I will have a look. But in two days my coolant level has gone from max to min  :sad:
« Reply #7 on: 01 August 2012, 09:33 »
Would a coolant leak cause the ecu to use less power?
Offline Dalo Harkin
« Reply #8 on: 01 August 2012, 12:42 »
in what way mate?
didnt make sense
Offline mar_k
« Reply #9 on: 01 August 2012, 17:26 »
Cracked thermostat housing
