might be an idea to check to see if all your plugs are sparking then, water down the spark plug holes could cause the plugs to arc out and cause a misfire, il also check to see if the plugs are actually wet around the electrobe, this could show signs of internal leakage again. If you dont have spark on just cranking it could be something non related to what happend with you previous water loss.
