Author Topic: Need help as normal lol  (Read 1976 times)
Offline ian007miles
« on: 29 July 2012, 15:58 »
Any one on here any good with suspensions(coilovers).my brother inlew fitted mine  now I'm get weird noises coming from all 4 corners I've figured the driverside noises out its the chassis rubbing on the driveshaft so that will need notching.but I'm seriously getting the arse wiv it all now so I am will to pay some one to sort it for me :wink: :wink: thanx ian
Agu|k03s|forge 007 dv|forge boost pipes|forge water pipes|forge tip|forge kona cold air intake|milltex 3" down pipe sports cat|milltek cat back exhaust|r-tech custom remap 238bhp and 235 torque
Offline GunnerCP
Re: Need help as normal lol
« Reply #1 on: 29 July 2012, 16:45 »
What arb do you have and what wheels do you have?
Offline jamie1989
« Reply #2 on: 29 July 2012, 17:42 »
1 - if the driveshafts are rubbing on the arb them notching will do nothing. You need a new arb that goes under the drive shaft or cut it off.
You only need a notch when you have a good arb that goes under the drive and your low enough to make the driveshaft hit the chassis.
2 - if all four wheels are making weird noises then I assume you need spacers to clear the struts etc to stop them rubbing.
Hope this helps  :grin:
1.6-1.8t AGU K03s, Forge actuator, Forge 007p, turbo back exhuast, Ths front mount, Catch can, 5 piece silicone boost pipes and creation sports tip. Stage 2 atm 232bhp 270lbs. Waiting for custom mapping :-)
Offline Toby
  • Car - less
« Reply #3 on: 29 July 2012, 17:43 »
whats a ARB??  :lipsrsealed: :rolleyes:
Currently down under
Offline Gti_Jamo
  • 1991 Corrado 1.8 G60
« Reply #4 on: 29 July 2012, 17:58 »
Anti-Roll Bar  :nerd:
Offline ian007miles
« Reply #5 on: 29 July 2012, 18:20 »
Anti roll bar has been removed all ready and already have 16mm spacers on the back and 10mm on the front and I have rotiform nue 18" by 8.5" wide with 215/45/18 tyres. I can see the drive shaft is touching the chassis. Thanx ian
Offline ian007miles
« Reply #6 on: 30 July 2012, 13:41 »
Some one mush no somthing ??????
Offline Xtrhardcore
  • Mk3 Gti 2.0 8v MoreDoor
« Reply #7 on: 30 July 2012, 14:43 »
You have no Arb? :shocked:
Mk4 Gti - Gone but not forgotten!
Offline dom
  • Back in a Mk4
« Reply #8 on: 30 July 2012, 15:09 »
If your low enough to need a chassis notch then an arb will be pretty ineffective anyway, it's quite common for people to just remove them :wink:
Did you replace the topmounts when fitting the coilovers?
Offline Xtrhardcore
« Reply #9 on: 30 July 2012, 15:10 »
Are the spacers Hubcentric?
