Author Topic: does a new actuator have to be mapped in again  (Read 6183 times)
Offline oceanic-green
  • Mk4 1.8T Aum 260+ Bhp 273 TQ
« on: 29 July 2012, 15:46 »
If my actuator is not working properly, and I bought a new one, say a Forge one. Would it have to be mapped back into my stage one r-tech remap ?
Mods: R-Tech custom remap, Beachbuggy K250 Turbo, Forge 007 DV, RAMAIR Jetstream 108 induction filter, silicone piping throughout, R-Tech Supersize TIP, 42 Draft Stealth Catch Can, N249 bypass, Ported Manifold, Toyo Sports FMIC with 2 & 1/2 pipes, Custom made full turbo back exhaust & 2 & 1/2 " downpipe and 200 cell sports cat. BAM injectors, Turbosmart Boost Gauge, BBS CK Wheels, 312mm Brembo front discs and pads, Carbon canister delete and last of all, a liquid cube!
Offline Chris.
Re: does a new actuator have to be mapped in again
« Reply #1 on: 29 July 2012, 15:51 »
ideally yes as your boost control would be too much with the harder spring.
Click For Build Thread
« Reply #2 on: 29 July 2012, 16:01 »
Oh :cry:
When you say "ideally" what will it be like if I can't get it mapped back in ?
Offline Chris.
« Reply #3 on: 29 July 2012, 16:49 »
Depends how hard the N75 was made to work to keep the stock actuator to meet the required boost.  Obvilously a weaker stock actuator will have a harder N75 map than a newer stronger one.
Putting a nice strong actuator on something that was previously mapped to cope for something weak will cause overboosts.
Could put it on and do some logs and see what people think?
« Reply #4 on: 29 July 2012, 21:15 »
My car was remapped by R-Tech roughly about 18 months to 2 years ago, and I expect the actuator was ok then, but since then has probably got weaker. I changed my N75 valve yesterday for the original c one, and it does seem a little bit better, but is still not how it should be.
A while ago it was over boosting with the newer N75 e valve up to about 22 psi, but this seemed to be ok once I sorted out the boost leaks, although it was still not driving how a remapped car should
« Reply #5 on: 01 August 2012, 09:59 »
As R-Tech seem impossible to get hold of, I phoned up another remap company which is close to me, and they told me that I don't need to get a new actuator remapped in, if it is just a faulty component then it should be able to be replaced with no problem!
Offline Chris.
« Reply #6 on: 01 August 2012, 10:31 »
Id double check with r tech. sure it would be best to do some logs of duty cycle.
« Reply #7 on: 01 August 2012, 10:39 »
That is easier said than done  :wink:
I Just spoke to them and as long as the new actuator is set the same as the old one then I won't need to get it mapped back in  :smiley:
« Last Edit: 01 August 2012, 10:42 by oceanic-green »
Offline Chris.
« Reply #8 on: 01 August 2012, 22:08 »
was that r-tech?
« Reply #9 on: 02 August 2012, 07:46 »
