Author Topic: Window wipers juddering...brand new car  (Read 6964 times)
Offline Markey1234
« on: 28 July 2012, 15:09 »
Picked my car up yesterday, brand new, and today used the wipers for the 1st time. They worked perfect for a few strokes then they started to judder both upwards and downwards. I have checked the rubber, all fitted correctly. The fact both are doing it coud be pointing the problem towards the windscreen?
Could VW have put some kind of rain repellant on it and that's causing the rubber to stick??
Any advice on how I should best clean the screen to try and sort this if it is the problem?...
2012 Golf GTD 5dr in Carbon Grey. DSG. 18" Charleston Shadow's. RCD510 with Dynaudio sound pack. Cruise control & luxury pack.
Offline Murrayedition35
Re: Window wipers juddering...brand new car
« Reply #1 on: 28 July 2012, 19:18 »
You could try wiping the blades with a newspaper, and then give your windscreen a good clean.
Offline Steve30
  • Ed30 .
« Reply #2 on: 28 July 2012, 19:37 »
Theres a product called Vinegar try that on the windows works a treat :grin:
Tiguan quicker than the Golf
Offline Ginge 35Edition
« Reply #3 on: 28 July 2012, 19:41 »
I've got to agree, it might be that the windscreen needs a bloody good clean or Is it a smearing issue or more of a motor type judder?
Offline JoeGTI
« Reply #4 on: 28 July 2012, 20:27 »
I've posted here on this subject before. I had the same problem from new on my GTD. Squeaking and juddering... Drove me absolutely nuts! I tried vinegar, I tried clay bars, I bought several expensive window cleaners/polishes, I tried RainX... I replaced the wiper blades twice! Nothing worked!
Then, for a completely unrelated issue, I had my windscreen replaced under warranty. My wipers have been blissfully silent ever since! I can only conclude that my original screen had some crap on it from the factory that just wouldn't budge. If the car is new, the wiper blades should be absolutely fine. I binned 2 perfectly good sets! Your problem, I am 99% sure, is the screen. You just need to find a way of cleaning it... Or more drastically, replace it.
« Last Edit: 28 July 2012, 20:29 by JoeGTI »
Offline Markey1234
« Reply #5 on: 28 July 2012, 22:25 »
Gave it a right good clean earlier with some strong glass cleaner, also gave it a light polish and cleaned the blades. Seems to be much better but they are till juddering a bit. The glass definitely felt quite resistant when I started cleaning, I could feel it getting easier and smoother as I was going so I think there is some sort of film over it. Ive been told to try the old school vinegar then dry with newspaper technique. I'll do this tomorrow.
If it doesn't work the car will be going straight to the vw dealer and will be there until its sorted.
Offline ScottA
« Reply #6 on: 28 July 2012, 23:09 »
Buy some Cerium Oxide (try eBay) and polish with a mf - will definitely sort it!
Offline Damo66
« Reply #7 on: 28 July 2012, 23:52 »
Methyletad spirit normally does it.....
Beetle (1975)
MK2 Golf GTI 16V
MK3 Golf GTI
Corrado G60
MK3 VR6
Passat Sport PDI
MK4 Golf GTI PDI 150
MK5 GTDI 140
MK5 Golf GTI
MK6 Golf R
MK6 Golf GTD
MK6 Golf GTI Ed 35
Beetle Sport TDI
MK7 Golf GTD
Offline Markey1234
« Reply #8 on: 29 July 2012, 00:23 »
In the morning I'll try vinegar, acetone and methylated spirit. If that still doesn't do the trick at least I'll have the cleanest windscreen in the land! :grin:
Offline Will@carbon
« Reply #9 on: 29 July 2012, 00:55 »
Clean the blades and the screen.
I don't believe in global warming, sorry.
How are speed bumps legal?
I dislike lorry drivers who block lanes in traffic.
All burglars must die slowly ASAP.
