The garage
intake pipe issue
Topic: intake pipe issue (Read 1331 times)
matping
Here all the time
MK1 20vT MK5 GTI T
intake pipe issue
27 July 2012, 22:39 »
mk3 16v . guys got a issue when i rev the car up the air intake pipe sucks itself shut and starves the car from air coming in from the air box its wierd but i spotted this with the bonet up ! ive had this issue a while whenever ive been driving the car would limit at 3000 revs and obviouslly this is the reason because when i get to 3000 revs thats when the air intake pipe will be closed untill i let go of the throttle
Rmachines
Passat 20vT Estate and Candy White MK3 1.8 GL
Re: intake pipe issue
04 August 2012, 14:55 »
Either the air filter/air box feed pipe is blocked, or the pipe has gone soft and weak, inspect air filter housing, then replace pipe.
10 golfs and counting!
Engine cranes = the ultimate tool to test the tensile strength of Everything you didn't disconnect!
The garage
intake pipe issue
