Author Topic: rear axle bushes  (Read 4239 times)
Offline Dan_GTi8v
rear axle bushes
« on: 27 July 2012, 16:19 »
I need new rear axle bushes and I've been thinking about powerflex bushes but on researching it have read a lot of bad experiences with them so am having second thoughts
How long would standard Febi bushes last on a lowered car? Anyone here fitted powerflex bushes to their rear axle?
cheers  :smiley:
Offline Gti_Jamo
  • 1991 Corrado 1.8 G60
Re: rear axle bushes
« Reply #1 on: 27 July 2012, 16:39 »
Ive got a polybushed rear axle and its fine, and there so much easier to replace than the normal metal/rubber bushes.
Offline Dan_GTi8v
« Reply #2 on: 27 July 2012, 16:44 »
yeah the easy factor is why I considered them in the first place, found a thread on Vortex though which had a lot of bad points about them. How long have you had them fitted?
Thread I found is here
Why (Rear) Poly Bushings Are Bad
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
« Reply #3 on: 27 July 2012, 16:56 »
Great summery in that thread on Vortex. These are the exact reasons I've never fitted poly bushes to any of my cars, I'd much rather stick with new OEM parts and allow the suspension to actually work as it was designed to.
Offline Gti_Jamo
« Reply #4 on: 27 July 2012, 17:33 »
Ive only had the car on the road two weeks so can't really say anything other that the run good at the moment and are well greases up but all the rest of my suspension is new. I'm not put off by that article as if I get a problem i'll just change them for other poly's. Turns a job that would normally take all afternoon into half an hour.
Offline Dan_GTi8v
« Reply #5 on: 27 July 2012, 17:56 »
so how long would regular febi bushes last on a lowered car roughly?
Offline Gti_Jamo
« Reply #6 on: 27 July 2012, 18:05 »
All depends on how the car is driven but if I was using I would expect a good few years out them.
VW BUSH
« Reply #7 on: 27 July 2012, 19:15 »
I did 45,000 miles on mine and they were in there when I got it :smiley:
Offline Dan_GTi8v
« Reply #8 on: 27 July 2012, 20:27 »
Febi it is then! Can get the bushes and the tool for the price of powerflex ones everyones a winner!
Offline Screech16v
  • MK3 20vt AGU
« Reply #9 on: 27 July 2012, 20:36 »
I fitted febi plus these inserts,so kind of somewhere in between standard and poly.
