Author Topic: Gear box removel  (Read 1122 times)
Offline mar_k
Gear box removel
« on: 26 July 2012, 15:22 »
Is it possible to remove the gear box without having to bleed the system?
Can I remove the clutch slave cyclinder with the pipes still attached
Offline jamie1989
Re: Gear box removel
« Reply #1 on: 26 July 2012, 15:46 »
Its easier to remove the slave still on gearbox. Bleeding is easy with a mate.
You changing the clutch I take it?
1.6-1.8t AGU K03s, Forge actuator, Forge 007p, turbo back exhuast, Ths front mount, Catch can, 5 piece silicone boost pipes and creation sports tip. Stage 2 atm 232bhp 270lbs. Waiting for custom mapping :-)
Offline mar_k
« Reply #2 on: 26 July 2012, 15:54 »
clutch and fly wheel,
how do you bleed the clutch without a easy bleed?
Offline Granta Gti
« Reply #3 on: 26 July 2012, 16:30 »
Just unbolt the slave then you don't have to bleed it
Offline mar_k
« Reply #4 on: 26 July 2012, 16:38 »
Cheers, that what I planned to do if it was possible,
Thanks a lot.
