Author Topic: Just bought......A 3" system! ***fitted***  (Read 50473 times)
Offline Dave_IOW
Re: Just bought......A 3" system! ***fitted***
« Reply #330 on: 21 November 2012, 23:15 »
Glad you guys have finally seen the light  :wink:
Pretty sure I was one of the first to have one of these sent over, said I was thinking about running a group buy on them and he knocked another £10 off  :grin:
Then got charged import duty/tax and messaged the seller about it and he fully refunded it!
Can't fault the bloke and received it really quickly, shame it didn't fit on the mk2  :sad:
Project: Mk2 20vT trackslag
Daily: Mk2 GTI typ19
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #331 on: 21 November 2012, 23:20 »
You could have chopped it up to fit lol
Offline xtetx
« Reply #332 on: 22 November 2012, 10:24 »
im getting the engine managment light on, says o2 sensor, shall i just replace it do you think?
Replacing it won't do anything.
The problem you have is that you've decatted the car.
The reason these run 2 o2 sensors is to monitor if the cat is working or not. It should see a different result at the second sensor after the car, but because you've got no cat it's seeing the same gas and thinking the cat isn't working, hence your light.
This needs to be mapped out.
Some people have used spacers and the like with varying success, but to do it properly and ensure the light doesn't come back you need the map altered to suit.
Cheers Prawny, you had a map on yours?
Im sure will be reet once i eventually book in at rtech  :grin:
Offline Prawny
  • R-tech power!!!
« Reply #333 on: 22 November 2012, 11:17 »
Yea man, you could say that  :whistle:
http://www.golfgtiforum.co.uk/index.php?topic=244468.0
Mine's an AGU though, so never had a second lamda sensor in the first place. I have a wideband AFR gauge hooked up to a sensor in the second hole in the downpipe :)
Offline xtetx
« Reply #334 on: 22 November 2012, 13:20 »
mate, that is so insane!  :grin: :grin:
need to sort out a few bits on mine, and ill be booking in to rtech!
you need to get a full build on here!  :grin:
Offline davemk4
« Reply #335 on: 22 November 2012, 15:27 »
So does this 3" better than the usual 2.5" for a ko3s?
2001 mk4 GTI 1.8t AUM. k&n induction kit with customer heat shield, 3'' TIP, Forge 007P, Stage 1 map, N249 bypass, 3'' downpipe and decat, 2.75'' Jetex cat back non res, Koni shockers and H&R springs 35mm, dimpled and grooved disks front and back
Offline Chris.
« Reply #336 on: 22 November 2012, 16:22 »
What size are these over the axle?
Just wondering if it would be cheaper to buy this exhaust and mate it up to my TT downpipe rather than buying 3" stainless straights and bends
Click For Build Thread
Offline Prawny
  • R-tech power!!!
« Reply #337 on: 22 November 2012, 16:42 »
3'' everywhere Chris.
I too was looking to make my own 3'' stainless system, and had priced up all the bends and straights, f-bands I'd need to make a really nice system, but when this came along, it worked out well over £100 cheaper, with no labour to pay either!
I bought the complete system, and sold the downpipe it came with for £70, so the entire system owes me £150.
it's fantastic.
Offline Chris.
« Reply #338 on: 22 November 2012, 16:45 »
Thats not too bad, I too would be left with a downpipe :(
However, im wanting to try make my remus backbox fit which I think is only 2.25" at the entrance to the backbox and twin pipes out.....it sounds soooo nice at 250bhp.
Somehow, I think a 3" pipe straight out the back will be a bit too much without a silencer maybe?
Offline golfyste
  • Project track car
« Reply #339 on: 22 November 2012, 17:05 »
It has a silencer at the back chris, a reasonably sized one at that but it's not restrictive so all good  :cool:
