Author Topic: MAF readings  (Read 2599 times)
Offline oceanic-green
  • Mk4 1.8T Aum 260+ Bhp 273 TQ
MAF readings
« on: 24 July 2012, 15:56 »
NOT SURE IF THIS SHOULD GO IN THE vagcom section or not  :undecided: but, I looked at my MAF readings today at idle, and they kept fluctuating up and down from 2.31 upto 2.86. Is this normal?
Thanks
Mods: R-Tech custom remap, Beachbuggy K250 Turbo, Forge 007 DV, RAMAIR Jetstream 108 induction filter, silicone piping throughout, R-Tech Supersize TIP, 42 Draft Stealth Catch Can, N249 bypass, Ported Manifold, Toyo Sports FMIC with 2 & 1/2 pipes, Custom made full turbo back exhaust & 2 & 1/2 " downpipe and 200 cell sports cat. BAM injectors, Turbosmart Boost Gauge, BBS CK Wheels, 312mm Brembo front discs and pads, Carbon canister delete and last of all, a liquid cube!
Offline scarr89
  • Mk4 Golf, DERV FTW!
Re: MAF readings
« Reply #1 on: 24 July 2012, 22:56 »
No idea mate  :sad:
Ummm, try a post in the remapping section if no one can help you here... :undecided:
Offline Scott D
Re: MAF readings
« Reply #2 on: 24 July 2012, 23:54 »
I think a reading between 2-4g/s is normal at idle for a healthy MAF.
2003 1.8T GTI 180 - APR Stage I, S2000 Filter, R-Tech Supersize TIP, Bilstein B12 Suspension, 18" OZ Superleggera, Recaro Heated Leathers, US Spec Rear Lights, N249/SAI/PCV Delete
1.8T AUQ - 241bhp & 286 ft-lb
R-Tech Map, Forge FMIC, SFS Oversized TIP, Ported Manifold, Milltek Turboback non res exhaust, Forge 007p, N249 & N112 delete, SAI delete, S2000 Air Filter, Sachs clutch & Lightweight Flywheel
nath20vt
Re: MAF readings
« Reply #3 on: 24 July 2012, 23:59 »
mine reads between 2.5 and 2.75 so seems bout right to me
Re: MAF readings
« Reply #4 on: 25 July 2012, 08:01 »
Does yours have a stage one remap?
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: MAF readings
« Reply #5 on: 25 July 2012, 17:32 »
get some readings on full chat  :wink:
Re: MAF readings
« Reply #6 on: 27 July 2012, 08:58 »
This will probably sound like a dumb question, but sorry I don't understand, what do you mean ?
Thanks  :smiley:
Offline Rhyso
Re: MAF readings
« Reply #7 on: 27 July 2012, 09:01 »
Thanks  :smiley:
Full chat = full throttle; like I explained in your other thread   :smiley:
Re: MAF readings
« Reply #8 on: 27 July 2012, 09:02 »
Thanks  :smiley:
Right ok, i got you  :smiley: Thanks
Re: MAF readings
« Reply #9 on: 27 July 2012, 09:05 »
Just to say, i have noticed that some of my threads seem to cross over into one another a bit, so sorry for that, its just they are a bit like the engines, everything is connected somewhere along the line  :laugh:
