Author Topic: OIL Level was really low  (Read 2615 times)
Offline mac456
« on: 23 July 2012, 12:27 »
Hi All,
My friend has asked me to find out about his Golf 1.8t agu.
He recently checked the oil level on his car and there basically nothing in there. no oil showing on the dipstick. Obviously enough to keep it running otherwise it would of seized.
He last checked the oil level in April and topped it up to the correct level. So in like 4 months it has used alot of oil.
Anything we can check? its  130kmile car. There is no sign of any smoking and the car runs perfect. Completely standard. No oil in water and no water in Oil.
Can is the oil level being that low effect the car in anyway?
Offline richw911
Re: OIL Level was really low
« Reply #1 on: 23 July 2012, 16:34 »
You should be checking oil MUCH more often than that! How many miles has it done since it was last checked?
Some Turbo engines are prone to use a bit of oil and an old 130k engine is bound to use some.
Check the sump / sump plug and oil filter for leaks.
Yes low oil can damage / cause premature wear it should NEVER be allowed to go below minimum .
« Last Edit: 23 July 2012, 17:00 by richw911 »
Offline dan2252
« Reply #2 on: 23 July 2012, 18:14 »
my mk4 1.8t it needs topping up once every week to  2 weeks its worst if i drive it hard  i do around 1200 miles a month and the cars on 170+k but 1.8ts are known for using oil so tell your mate to keep a eye on it!
MK4 golf 1.8 turbo agu :)
« Reply #3 on: 24 July 2012, 00:03 »
I must be lucky, mine does not use any and it gets checked every week.
Offline simon_709
« Reply #4 on: 24 July 2012, 06:46 »
My old engine was on 158 and never used any oil in 7months and I did about 7k in that time. Always checked it every week though.
My Golf GTi, RS4 reps 17", coilovers, tinted windows, De-cat and middle box removed with 3" oval back box, stage 1 Revo re map, G60 flywheel/VR6 clutch, HID kit, Forge 007p,
Offline richw911
« Reply #5 on: 24 July 2012, 16:05 »
Mine is also very good rarely needs any oil at all - sometimes it may need drop but only after thousands of miles  :smiley:
Offline Steve_PD
« Reply #6 on: 24 July 2012, 16:46 »
You only do 5 miles a week so it shouldn't use any :tongue:
Offline richw911
« Reply #7 on: 24 July 2012, 18:21 »
Not any more it gets used every day now for work  :wink: Still an old 150k motor anyway  :tongue:
Offline dan2252
« Reply #8 on: 24 July 2012, 19:27 »
i think it all depends on how theyve been looked after in there life, mines got no previous history only a print out from a garage in london 5 years ago for service and spark plugs, but after ive replaced the pick up pipe and gave the engine a good service its lovely and quiet, my stem seals are the fault with mine i belive
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #9 on: 24 July 2012, 20:43 »
67k and the oil stays on max permanently  :wink:
