Author Topic: wet carpet  (Read 2509 times)
Offline Tazzy
wet carpet
« on: 22 July 2012, 13:07 »
hi guys
the car has got wet carpet infront and behind the driver seat
i will be honest, the golf only gets used on a sunday for only a couple of hours in the afternoon, it sits on my drive doing nothing throughout the week
where and how is the water coming from?
cheers ta, thanks very moochos
If It Comes Off, Modify It!
Offline GTi_James
Re: wet carpet
« Reply #1 on: 22 July 2012, 13:45 »
theres a number of posts for this already, mainly take your air filter out n make sure its dry, find all the drain nipples, front door hinges, under rear bumper, air vents next to rear drain nipples if sunroof, and finally remove all your door cards and butyl seal around the inner card finally pull up carpet and drain your lagoons, should sort it out, also check the accelerator feed as the rubber grommit may of moved.
just a checklist i went through yesterday
Offline willsgolf
Re: wet carpet
« Reply #2 on: 22 July 2012, 14:06 »
I had this a few months ago mate. Take your front wipers off remove the scuttle pannel and check where the hinges of the bonnet are theres normall aload of crud in the wing so stops the water draining properly. Well thats the point i would check first before taking all the door cards off :D hope this works for you mate.
Offline Hoggy
  • Mk4 GT TDI 150.
Re: wet carpet
« Reply #3 on: 22 July 2012, 14:39 »
Pollen filter, not air filter  :wink: haha
If no luck with underneath the scuttle, maybe its the window regulater panel thats leaking in behind the door card?
Offline barrym381
Re: wet carpet
« Reply #4 on: 22 July 2012, 14:54 »
thats were i had my leak on my leon  :smiley:
Offline sambo1670
Re: wet carpet
« Reply #5 on: 22 July 2012, 16:29 »
had this last weekend, took the inserts out of the door as pictured above resealed them with silicone, and cleaned the drian holes out under the seal on the bottom of the door. worked a treat.
Offline barrym381
Re: wet carpet
« Reply #6 on: 22 July 2012, 16:38 »
an when it gets cold your leak will be back  :grin: :grin:
Offline GTi_James
Re: wet carpet
« Reply #7 on: 23 July 2012, 09:58 »
What he said  :lipsrsealed:
Offline Tazzy
Re: wet carpet
« Reply #8 on: 23 July 2012, 21:16 »
hmmm, so many possibilities, thanks guys
Offline Steve_PD
Re: wet carpet
« Reply #9 on: 23 July 2012, 22:22 »
If its the drivers side it won't be the pollen filter. My bets are on the window seal/door seal leaking
