Author Topic: Best way to tackle this issue...pics enclosed  (Read 2800 times)
Offline quattro.andy
« on: 20 July 2012, 21:09 »
Hi All,
Noticed that I was letting in water through the pollen filter/heater fan area.
Thought it was possibly the drainage areas but after looking quickly noticed the issue...
Now, is this seal a part of the scuttle or the windscreen?
Many thanks
Andy
« Last Edit: 20 July 2012, 21:12 by quattro.andy »
Offline Deano2711
  • 1992 VR6
Re: Best way to tackle this issue...pics enclosed
« Reply #1 on: 20 July 2012, 21:15 »
Part of the scuttle panel I believe.....is the windscreen not bonded in ??
Offline Dan_GTi8v
« Reply #2 on: 20 July 2012, 21:16 »
im pretty sure its part of the scuttle
Offline ant_gti
  • mk3 20v turbo
« Reply #3 on: 20 July 2012, 21:18 »
yep part of the scuttle cover and a nightmare to get a mint one i need one myself.
« Reply #4 on: 20 July 2012, 21:19 »
That seal is part of the scuttle panel.
« Reply #5 on: 20 July 2012, 21:25 »
What I think is happening is the water is going through the gaps onto the pollen filter and into the car that way? or do I have overlooked something?
The water is running into the car from the left so just assumed I had found the issue?
Offline Screech16v
  • MK3 20vt AGU
« Reply #6 on: 20 July 2012, 21:35 »
I wouldnt say that seal is critical,my scuttle has no fixings and the seal is not tight against,my car dry as a bone even with all this mega rain,have you got any rust above the screen or checked the gasket under the filter?
« Reply #7 on: 20 July 2012, 21:39 »
I have not had the scuttle off yet to investigate more - I take it I have to take the wiper arms off and the big black screws?
Pollen filter housing sounds a good bet as of the location of the water getting in?
Offline Screech16v
  • MK3 20vt AGU
« Reply #8 on: 20 July 2012, 21:48 »
Yeah them screws are a pita  :grin: hope ya find the culprit my leak was rust hole above the screen ,water would run down the side of the screen and drip down from between the a post and dash ,could see rust stains in the gap
« Reply #9 on: 20 July 2012, 21:52 »
Will have a poke around over the weekend, may be a good idea to stick my head under the passenger side dash as a trusty associate soaks me with water! ;)
