Author Topic: Do wishbones need to be torque up  (Read 4548 times)
Offline Jimmyrallye
  • 20vt goodness
« on: 20 July 2012, 10:16 »
Going to fit my wishbones later when i get in from work do the new wishbones need to be torque up in any way ? Thanks :)
Offline Diamond Hell
  • Opinions я Us
Re: Do wishbones need to be torque up
« Reply #1 on: 20 July 2012, 10:51 »
They're control arms, not wishbones.
Yes, all bolts will have a torque specified, but as you're bolting up the subframe at the back, I'd just give it a good erk and be done with it.
This assumes you're confident in your erk value, otherwise get a Haynes and have a look for the torque figure.  In my experience I have not had the control arm mounting bolts come loose.
Offline Jimmyrallye
  • 20vt goodness
« Reply #2 on: 20 July 2012, 11:04 »
That wos my game plan to do them up fooking tight just didnt want them to start creeking or anything as ive got a torque wrench just save doing job twice .. Need to invest in a haynes as well .. Thanks for getting back to me ;)
Offline Agreeable Slick
  • Unit
« Reply #3 on: 20 July 2012, 11:14 »
If you have a torque wrench then you might as well use it, at least then you won't second guess your "erk"
Offline Dolly
« Reply #4 on: 20 July 2012, 13:17 »
If you need to ask the question, then yes torque them.
  • Opinions я Us
« Reply #5 on: 20 July 2012, 13:46 »
Provided you have the torque figure and you know your torque-wrench is calibrated accurately.  :wink:
Offline danny_p
« Reply #6 on: 20 July 2012, 19:05 »
if the OP is built like beavis   a torque wrench is essential
all the VW's have gone bar 1.
Offline Jimmyrallye
  • 20vt goodness
« Reply #7 on: 20 July 2012, 22:04 »
All sorted :) have to change a arb bolt on passenger as it snappec of but quite a easy job .... So glad i bought the metal shims as got to told you do/dont need them i can confirm you do need them!!! Also changed top mounts
Offline Gambit
« Reply #8 on: 20 July 2012, 22:13 »
You only need them if you stick with the mk2 bushes, if you go for the uprated tt rear wishbone bushes you dont need the guides. If id have seen this earlier id have told you to get the tt bushes before fitting the wishbones
Offline Jimmyrallye
  • 20vt goodness
« Reply #9 on: 20 July 2012, 22:19 »
I bought the wishbone completed with everything so new bushes all round .... There wos no way on earth on getting the old shims out as i had to hammer and bolster one out !!! Can get my tracking and camber sorted now as well , do the audi tt bushes make a big difrence ?
