Author Topic: Going to sort This 5000rpm limiter issue, a little help??  (Read 3226 times)
Offline OffEdge
Hi there all,
The weekend i am going to try and solve my 5000rpm limiter issue i have, i have read up about the causes and i am hoping that it is just the Rotor arm out or the hall sender,
so am i right in saying i have to take the cambelt covers off, put the car at TDC, take green cap off gearbox to back sure the flywheel is correct then take the dizzy off and line the rotor arm up? or is there more to it than that? as i have read that TDC is done of Piston no1 on these engines? how do i tell if i have piston1 at TDC lol?
Many Thanks
Offline JayNesbitt
Re: Going to sort This 5000rpm limiter issue, a little help??
« Reply #1 on: 19 July 2012, 13:50 »
I could do with some advice on this front...im clueless :(
Offline Gti_Jamo
  • 1991 Corrado 1.8 G60
« Reply #2 on: 19 July 2012, 14:24 »
Basically you want to put a long thin screwdriver down piston number one and turn the engine by hand until it reaches its highest point. The marks on the camshaft pulley and flywheel should then line up. Then take the distributor cap off and you will see a grooved mark on the distributor that the rotor arm must line up with. if it doesn't then slacken off the 13mm bolt and turn the distributor until it does then put it back together and give it a try.
« Last Edit: 19 July 2012, 14:26 by Gti_Jamo »
Offline Len
« Reply #3 on: 19 July 2012, 14:49 »
It maybe the cambelt one notch out!
www.sas.org.uk
www.the-ace.org.uk
Offline OffEdge
« Reply #4 on: 19 July 2012, 18:10 »
Just in the middle of doing this now, are there any marks on the cam pully that need to line up? Also is piston1 closet to airbox drivers side or gearbox side lol
Offline Gti_Jamo
« Reply #5 on: 19 July 2012, 18:26 »
Yes piston number one is closest to airbox. There should be a mark on the cam pulley and an arrow on the side of the cam cover that line up.
Offline OffEdge
« Reply #6 on: 19 July 2012, 18:33 »
Also I can't see the 13mm nut to undo to adjust the dizzy? There's one holding a big black thing down under the dizzy lol
Offline topher
  • Administrator
  • fully functioning
« Reply #7 on: 19 July 2012, 18:42 »
you need to hook up vagcom and see if its got any faults logged to do with the hall sender. it might just need a quick twist of the dizzy, you need to be watching the measuring blocks in vagcom to see when you're in the right spot. i think its measuring block 7
Offline OffEdge
« Reply #8 on: 19 July 2012, 18:45 »
Okay then, I might just put it back together lol, does anyone have vagcom close to dudley?
Offline Gti_Jamo
« Reply #9 on: 19 July 2012, 18:46 »
There is a V shaped clamp with a 13mm bolt at the base of the distributors, slacken it and it should move. I set mine without using vagcom, just a code reader showing hall sensor fault although it will never be exact and you really need it set to the correct values. Why do you believe it out of tolerance anyway? has it had a recent cam belt?
