Author Topic: Brakes soft after fitting ARB  (Read 2207 times)
Offline JoelBu
« on: 19 July 2012, 08:31 »
Hey guys,
Just wondering if anyone's got any ideas, since fitting a new ARB after lowering, when I put my car onto full lock the brake pedal will sink to the floor and the braking is very soft, it returns to normal after pumping pedal a little, and is absolutely fine when not on full lock??
Anyone experienced this as well??
Mk4 1.8t, ko3s, miltek exhaust, JOM coilovers,
Offline theshrew
Re: Brakes soft after fitting ARB
« Reply #1 on: 19 July 2012, 16:50 »
Have you broken a pipe is fluid level ok ?
Nothing arb related would affect the brakes so maybe you broke something or its just so happends something has fail at the same time.
If you have soft brakes dont drive it till its fixed
Offline DunnDeal12
  • Limited
« Reply #2 on: 19 July 2012, 17:22 »
Hey guys,
think you've broke something fitting the arb
Offline 1.6mk4GOLF16v
« Reply #3 on: 19 July 2012, 22:53 »
check you breaklines
my coilovers actually cut clean through on the drivers side, now ive cable tied em on
1.6 16v AZD
RS8s 225/35/19
Full powerflow decat exhaust
Blanked EGR
Pipercross panel filter
watch this space for the rest...
Offline km
« Reply #4 on: 19 July 2012, 22:57 »
i experienced this when my wheel bearing was fooked. wheel would push pistons in i'd imagine, so when i press the pedal it would go down to floor. just a suggestion.
Offline scarr89
  • Mk4 Golf, DERV FTW!
« Reply #5 on: 20 July 2012, 08:26 »
 :sad:
Check it all out, probs damamged something. Time to take the wheels back off.
« Reply #6 on: 20 July 2012, 09:33 »
Sounds like you have damaged a brake line.
Offline JoelBu
« Reply #7 on: 20 July 2012, 10:13 »
Excellent, thanks ever so much guys, will whip the wheels off tomorrow and have a look,
Will post update then,
Thanks again
Offline JoelBu
« Reply #8 on: 24 July 2012, 01:19 »
Problem solved.
It appears that the reason braking was crap on full lock was due to the brake cables kinking when stretched round the coil over on full lock, as it didn't fit in the clip due to lowering.
Cable tied it to the coilover to reduce movement and problem solved :-)
Happy days, Thanks all!!!
