Author Topic: braided brake hoses/lines  (Read 16491 times)
Offline sharki786
  • GOT BOOST??
Re: braided brake hoses/lines
« Reply #40 on: 02 March 2013, 10:56 »
Righty then. I got my braided lines yesterday and iv seen them but they look skinny :undecided:
Anyway a pic of them:
Is that right?
*****MK3 Anniversary*****
*****MK4 GTI T*****
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
« Reply #41 on: 02 March 2013, 21:49 »
Look good to me.
Offline sharki786
  • GOT BOOST??
« Reply #42 on: 03 March 2013, 17:21 »
Look good to me.
Cheers mate. Im sure the hel braided lines i saw were slightly thicker.
Anyway just rebuild my old mans nissan almera caliper (handbrake lever seized) common. But its a bugger to put back together. Its the spring that needs compressing. Anyway will start my calipers soon.
*****MK4 GTI T*****
Offline F17BAD
  • Golf MTM S3 GTI TURBO
« Reply #43 on: 04 March 2013, 18:36 »
look ok, only issue i see is non stainless ends/fittings as found on Hel / good ridge
 :wink:
Not no ordinary GTI....
www.mixcloud.com/kells/
Offline Foreveryoungaus16v
« Reply #44 on: 04 March 2013, 20:04 »
Thought u decided Goodridge?
163 BHP (TSR POWER RUN)
VW BUSH
« Reply #45 on: 04 March 2013, 20:10 »
The stainless fittings and braided cover are for show really, zinc plated ones will live long enough and are just as strong if not stronger.
They will just look a bit rusty next year, which is not good for someone with car OCD :whistle:
My hoses are uprated and look just the same as a normal pipe, very boring I know :grin:
Offline sharki786
  • GOT BOOST??
« Reply #46 on: 04 March 2013, 20:27 »
 :wink:
I know i didnt think. Oh well.
I did but then i got mk4 rear calipers so couldnt be arsed faffing about with trying to get the correct ones. The buyer i got these from had the fronts so i got them all together from him
Where i work we do electro plating which is zinc lol but i have been moved up a level to zinc nickle plating (most expensive in the place)
Im more than happy with them.
*****MK4 GTI T*****
VW BUSH
« Reply #47 on: 04 March 2013, 20:34 »
where do you work, its not on aston science park is it?  I deal with a few surface treatment specialists up there who do some exotic stuff
Offline sharki786
  • GOT BOOST??
« Reply #48 on: 04 March 2013, 23:29 »
Done live far from aston science park. I work in digbeth (A Gilligans) zinc plating
*****MK4 GTI T*****
Offline F17BAD
« Reply #49 on: 05 March 2013, 11:23 »
Zinc plate will no way ever last aslong or be as strong as stainless, Infact I dare say they would corrode after time
The overbraid is not for show its to keep the lines firm I was told by the guy at HEL
Where I work we use zink nickle plate and its used on cheap valves. The better valves are always stainless steel, 316, F51 etc
I wouldn't say no to having them on the car but I'd still
Rather have the stainless versions
