Author Topic: braided brake hoses/lines  (Read 16471 times)
Offline boneybradley
  • Back in a Mk3...
Re: braided brake hoses/lines
« Reply #20 on: 23 February 2013, 15:05 »
Ok got some calipers with the standard lines and carriers for cheaps :evil:
My question is will my hand brake cables fit into the mk4/bora calipers?
hand brake cables are fine, and you don't need the carriers and the hoses wont fit. you need to buy some conversion hoses (and posted earlier) as the connections differ. most goodridge sellers will do a full kit inc conversion hoses (might be worth emailing a few?)
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
« Reply #21 on: 23 February 2013, 15:18 »
These are the hoses i have... in my shed. http://www.ebay.co.uk/itm/121067971306?ssPageName=STRK:MEWAX:VRI&_trksid=p3984.m1423.l2661
Want to sell them??
That means i got to buy the fronts sep?
No, they'll be fitted when i get the chance, isn't so cold...can be arsed.
Offline sharki786
  • GOT BOOST??
« Reply #22 on: 23 February 2013, 16:24 »
Im sure my rear calipers are banjo fitting (lucas) so realy should fit? If not then i need to get the convo kit and 6 line kit???
*****MK3 Anniversary*****
*****MK4 GTI T*****
Offline Screech16v
  • MK3 20vt AGU
« Reply #23 on: 23 February 2013, 18:09 »
Make sure you check the bleed nipples on the mk4 calipers as they like to rip the threads out on removal/cracking off for bleeding
Offline Foreveryoungaus16v
« Reply #24 on: 23 February 2013, 18:58 »
Do ur hoses act need changing?
163 BHP (TSR POWER RUN)
Offline sharki786
  • GOT BOOST??
« Reply #25 on: 23 February 2013, 19:48 »
Dont know when they been changed. And im actualy upgrading to the braided type anyway.
*****MK4 GTI T*****
Offline sharki786
  • GOT BOOST??
« Reply #26 on: 23 February 2013, 19:49 »
Going to throw them into deruster at work tomoz anyway so shouldnt be an issue to crank open anyway :wink:
*****MK4 GTI T*****
« Reply #27 on: 23 February 2013, 19:50 »
I was thinking of doing that to but advice I been given unless u drive your car hard or do track racing no real point if there is nothing wrong with your hoses
« Reply #28 on: 23 February 2013, 19:51 »
But up to u if you want to spend £80ish on some
Offline sharki786
  • GOT BOOST??
« Reply #29 on: 23 February 2013, 20:25 »
Well a guy who workz with me has them fitted to his type r and siad that you get a better feel of the brakes and braking is improved aswel.
Will i be able to use my normal rear discs? They are 226mm (i think)
*****MK4 GTI T*****
