Author Topic: changed engine now fault code :( 17656 ...  (Read 2851 times)
Offline terryuk
« on: 17 July 2012, 23:11 »
hi guys i broke the cam shaft in my asv engine so fitted a ahf both 110 bhp and look the same .. i did the work myself apart from asking my very good mecanic friend to look at some things and fit the cam belt . i took the old engine out spilt the box re fitted the clutch an fly to my new engine fitted all other parts all new oil belts and filters .
now i have a fault code 17656 ... i fitted the asv fuel pump but left on the ahf injectors could this cause this problem   ... tickover sounds nice revs like a bag of s..t  lots of diesl noise no boost to 2500 rpm then after that 100% boost  coan you guys help ? thanks terry
Offline EsSeX dAn
Re: changed engine now fault code :( 17656 ...
« Reply #1 on: 18 July 2012, 01:50 »
have a look at this chap http://wiki.ross-tech.com/wiki/index.php/17656/P1248/004680
from what i can gather it sounds like the fuel pump timing is out
i think i love you.....
Offline terryuk
« Reply #2 on: 18 July 2012, 15:40 »
thanks yea i think you are rite the timeing is out im a little sick of it now as i just want the car to run rite but hopefully it will soon :)
Offline terryuk
« Reply #3 on: 18 July 2012, 23:09 »
hiya iv done the pump timing today and it runs and sounds lovely :) thanks for your help terry
Offline EsSeX dAn
« Reply #4 on: 23 July 2012, 21:53 »
top job. how did u break the cam shaft out of interest?
